Is this the front axle I want for SAS?
Is this the later model axle suggested for a SAS?
I heard 85 was the best year? Is this one? Thanks guys. http://i935.photobucket.com/albums/a...luxx/axles.jpg |
That axle is older like 79-83 but you can still use this as your front. the lower truss will be physically longer on the axle tube 84-85 thats how you can tell. truss will continue past the spring perch
Whats the difference? Oh...see you added the info thanks.
Not an 84/85 as it only has a half bottom truss.
79-81 no truss, 82-83 half truss. :wabbit2: |
Thank you too Mr Wabbit.
I keep wanting an older pickup for a solid axle....then I was like duh! Just sas the 87 runner and be done with it. It will be awhile though. Is $250 for both axles in pic above decent price? |
I'd say yes. Even better if you can talk em down.
Yup that axle will work
i usually get $350 for a front complete hub to hub.
| All times are GMT -8. The time now is 06:26 AM. |
