frame to ground height with sas kit.
I was curious what your frame to ground height is with 4 inch sas lift and 33s
If i could get a couple measurements that would be really helpful in helping me decide wether i want to go with 4 or 5 inch leafs. Let me know what kit you have and tire size you are running thanks guys. I really leaning toward the 4 inch springs when i do my swap. Rite now i have 63 chevys in the rear (no block) ifs 4 inch trail disaster in front and the rear probly sit a good 2 inches higher in rear. |
I have 4" front and 5" rear with 38.5's mine measures 30" to the bottom of the frame.
85 4Runner w/ 5" springs on 40s and I sit at 26" to the frame under the driver's seat
I went with the 4" leaf springs on my 85 ext cab (in process now) to clear 35s and keep the sheet metal. With an extended cab, I would suggest the 4" springs front and rear. SAS lift kits: http://www.wabfab.org/products/suspension/saskit.htm Classic rear lift kits: http://www.wabfab.org/products/suspe...earliftkit.htm :guitar: |
