Argghhh!!! Another bent axle housing discovered too late! Can it be saved?
I am trying to get this SAS done, but for the second time now I think I have wasted time with a bent axle.
The first housing I started with got all the way painted and was installing the pass side birfield when I noticed that the housing was bent back on the short side... Into the junk pile it went, along with nice solid steering stops and a trailgear front diff guard. SO..... I bought this housing for $40 of CL, and now I believe it is bent upwards on the driver's side now. I can lift the axle up to center in housing, but its normal resting place is down about 2mm at the axle seal location. I still have a nice Ballistic upper truss, which is SOOOO much nicer in fit and design then the TG truss, but I don't want to waste it. My hope is I can find a way to flex it straight and then weld on the upper truss. Thoughts? https://i1206.photobucket.com/albums...1/DSC06045.jpg https://i1206.photobucket.com/albums...1/DSC06048.jpg |
This is why I buy new axle housings now. 25 year old ones have a tendency to get bent. :hillbill:
:wabbit2: |
Bobby Long can fix these for you. He's located in Graham
Link to his posting on NW wheelers: http://www.nw-wheelers.com/forum/showthread.php?t=53053 Link says he charges $100.00 to fix. Longfieldsuperaxles.com ORDER LINE 360-893-0235 TECH LINE 253-847-8254 OPEN 24 HOURS |
Originally Posted by waskillywabbit
(Post 51683817)
:wabbit2: where can you buy new housings from? sounds like something i might need to look into. sorry for the thread jack. |
I'm going to check out Longfield and see if he can straighten it... I am tempted to weld up the upper truss first and then bring it to him so I know it is PERFECTLY straight.
I can't afford to spend $750 for an axle housing at the moment, regardless of how good it might be. One other reason I don't want to go with a new TG housing is that they are 3" wider then the stock housing, and i am planning on using IFS hubs so I can have slip-off rotors. If I use a Rock Assault housing it will be 6" wider! |
Originally Posted by dma251
(Post 51683852)
Ah... Yes, that's a good kit that's also on my list of too many to do's:wrench: |
Well, scratch the Longfield plan. He is no longer offering that service...
Does anyone know of anyone in the Snohomish county area that can straighten this? It seems like a pretty simple operation to me, but I don't have one of those great big steel welding tables where you could chain down the axle and start tweeking it.... Do machine shops do this? |
I'd say your fine. Run a set of Marlin HD seals and call it a day.
Originally Posted by 87hillbillyoter
(Post 51683841)
and rock assault axles from trail gear. Both look pretty beef, more or less the same thing. |
I believe Dave from Davez Off Road will straighten it. Give him a call. Shipping may nix the whole deal though.
http://www.davezoffroadperformance.com/ |
Originally Posted by yotaman
(Post 51684195)
BigMike |
Originally Posted by BigMike
(Post 51687597)
It's hard to tell from the picture how bent the housing really is (the axle is just resting/drooped), as good as our EcoSeals they are not the answer to a bent axle housing -- rather they are the answer to improperly shimmed knuckles.
BigMike Basically I was saying put it together and see if it works before spending a lot on trying to fix an axle that may not be bent all that much. |
(Post 51687597)
BigMike It's bent, no question about that... |
Pretty sure you can cut a relief notch on the top of the axle, then weld a small truss on the bottom of the axle to shrink the metal on the bottom, thus un-bending your knuckle.
then simpky re-weld up the top.. tried to find a writeup, but our search function is pretty terrible. |
(Post 51683810)
The first housing I started with got all the way painted and was installing the pass side birfield when I noticed that the housing was bent back on the short side... Into the junk pile it went, along with nice solid steering stops and a trailgear front diff guard. SO..... I bought this housing for $40 of CL, and now I believe it is bent upwards on the driver's side now. I can lift the axle up to center in housing, but its normal resting place is down about 2mm at the axle seal location. I still have a nice Ballistic upper truss, which is SOOOO much nicer in fit and design then the TG truss, but I don't want to waste it. My hope is I can find a way to flex it straight and then weld on the upper truss. Thoughts? https://i1206.photobucket.com/albums...1/DSC06045.jpg https://i1206.photobucket.com/albums...1/DSC06048.jpg James |
Originally Posted by peow130
(Post 51687627)
then simpky re-weld up the top.. tried to find a writeup, but our search function is pretty terrible. Thank you for the tip. If the shop I found can't straighten it, I will Try this method. Sounds like a good last-chance idea. This is the type of information I was hoping for rather then the usual second-guessing. |
Originally Posted by JamesD
(Post 51687672)
What year is that axle housing? I cannot tell from the pictures.
James |
(Post 51687613)
I understand that fact and agree completely. It may in fact not be bent that much. I think it may just be the axle resting. Without the proper tool it'd be hard for someone to say for a fact the axle housing was bent.
(Post 51687614)
if you turned the housing upside down, the axle would be in the same position it's in right now - pressed against the edge of the oil seal recess. If i pull on the axle shaft, i can pull it to almost reach the exact center of the housing, but it will return to it's "rest" position up against the oil seal...
see page 2 of this thread on how Dave's Off road straightened an axle
| All times are GMT -8. The time now is 09:40 AM. |
