Ozarks Ozarks Chapter
Keith's bumper ideas
Old Feb 8, 2007 | 01:04 PM
Cargun's Avatar
There ya go... black is what you got, red are my suggestions, green is your frame, red dotted is optional routing of the side supports.
Old Feb 10, 2007 | 09:57 PM
Exeter's Avatar
wow just noticed this...
Well, first off... do i want to weld or bolt this beast on there?
Next.. would any 'ole hitch from tractor supply co. or similar be good? (assuming thats what the red rectangle is ) And can i get some D-rings there too? How 'bout difficulty of adding those?
Thanks.
Old Feb 11, 2007 | 02:47 PM
Cargun's Avatar
Combination of bolting and welding. The brackets that go into the rear of the frame are bolt on, the rest of the stuff is welded. I'd even recommend welding the brackets to the frame in addition to bolting them, that adds a lot of strength and rigidity.
Yes, the red rectangle is a receiver from TSC, if it was from somewhere else I would have made it a different color.
I hope you aren't planning on running a spare tire under there? If so, you may have to get creative with the two red supports.
Old Feb 12, 2007 | 07:06 PM
colsoncj's Avatar
So, whatever happen with this... are you getting it, got it?
Old Feb 12, 2007 | 08:01 PM
Exeter's Avatar
probably will be getting it after this next trip and i check on money for my tires and such. still need to know where i can get some tube to add to this bumper?
Old Feb 12, 2007 | 08:02 PM
colsoncj's Avatar
any metal supply place will have some
icentropy
Sep 16, 2020 02:47 PM
lledwod
Aug 30, 2016 01:03 PM
nick9455649
Sep 11, 2015 05:10 PM
lectric80
Jul 29, 2015 12:25 PM
