Tillamook State Forest: restrictions in Place due to High Heat
Oregon Wheelers:
Effective 7/28 Tillamook State Forest Now Closed--see post #6 below Found this on a Local wheeler board about Tillamook state forest, Brown's camp etc. Just a heads up to call the Oregon Department of Forestry before you head out.. http://newweb.wrh.noaa.gov/total_for...il=FWF&sid=PQR http://egov.oregon.gov/ODF/FIELD/TIL...on/nw_IFPL.pdf
Originally Posted by Crawler
Sent: Monday, July 27, 2009 11:34 AM To: Tillamook Notifications Cc: ALL TILLAMOOK; ALL TILLAMOOK FOREST CENTER; ANDERSON Chuck H; DISPATCH Astoria; GROSSE Marjorie H; BRADFORD Jill M; WHITE Andrew Subject: NW-1 to Level II, NW-2 & NW-3 to Level III (effective 0100 at 7/28/09) EFFECTIVE 0100 ON 7/28/09, NW-1 goes to IFPL 2 and NW-2 & NW-3 go to IFPL 3. Shutdown restrictions are listed below. (Tillamook District is now only comprised of zones NW-1 and NW-2, the district boundary with Forest Grove District is the boundary between NW-2 and NW-3.) http://egov.oregon.gov/ODF/FIELD/TIL...ges/Protection /nw_IFPL.pdf The Level changes also affect OHV use on the Tillamook State Forest . Browns Camp , Jordan Creek, Diamond Mill, and Trask and the trails in the BLM Nestucca Riding Area are CLOSED and will remain closed until further notice. The gravel roads in the Browns Camp , Jordan Creek, Diamond Mill, and Trask areas remain open for OHV use. All Designated posted dispersed sites on the Tillamook District are now closed for campfires. Campfires are only allowed at Designated Campgrounds ( Jordan Creek , Keenig Creek, Jones Creek, Diamond Mill, and Nehalem Falls ). Under Industrial Fire Precaution Level 3, the use of fire or power-driven machinery in any operation area is unlawful unless such use is in compliance with the following: Complete Shutdown. The following activities are not permitted at any time, except as noted: 1. Cable yarding systems, except gravity systems using non-motorized carriages may operate between 8:00 p.m. and 1:00 p.m., when all blocks and moving lines are suspended at least 10 feet above the ground (except the line between the carriage and the chokers). 2. Power saws, except power saws may operate at loading sites and on tractor or skidder operations between 8:00 p.m. and 1:00 p.m. 3. Tractor, skidder, feller-buncher, forwarder, and shovel logging operations, except if equipment with a blade capable of constructing a fireline is immediately available and able to quickly reach and effectively attack a fire, then operations are allowed between 8:00 p.m. and 1:00 p.m. Partial Shutdown. The following activities are not permitted between 1:00 p.m. and 8:00 p.m.: 1. Mechanized loading or hauling of any product or material. 2. Blasting. 3. Welding or cutting of metal. 4. Any other spark emitting activity not specifically mentioned. Under Industrial Fire Precaution Level 2, the use of fire or power-driven machinery in any operation area is unlawful unless such use is in compliance with the following: Partial Shutdown. The following activities are not permitted between the hours of 1:00 p.m. and 8:00 p.m., except as noted: 1. Power saws, except power saws used at loading sites. 2. Cable yarding. 3. Blasting. 4. Welding or cutting of metal. ...UNSEASONABLY HOT THIS WEEK WITH INCREASING MID-LEVEL INSTABILITY... Here is the link to the National Weather Service: http://newweb.wrh.noaa.gov/total_for...rod.php?wfo=pq r&pil=FWF&sid=PQR Thanks! Jennifer Jennifer Wallmark OS2/Lead Dispatcher ODF – Tillamook District 503-842-2545 If you guy's have any questions about wheeling in these area's please contact ODF-Tillmook District. |
stickied :)
its too hot to be outside anyways :
Originally Posted by Tofer
(Post 51192826)
stickied :)
Originally Posted by Elton
(Post 51192845)
i was out side like 10mins and was soaking wet from the sweat it says 102 in the shade give or take and thats here near the coast
Brown's Camp/TSF Closed effective 7/28
Brown's Camp/TSF now closed due to High Heat
Hi Everyone, Due to an increase in Fire Danger and the Industrial Fire Precaution Level being raised to an IFPL 3 – the OHV trails in the Tillamook State Forest (Browns Camp, Jordan Creek, Diamond Mill, and Trask) and the OHV trails in the BLM Nestucca Riding Area are CLOSED effective at 1:00 AM Tuesday, July 28th and will remain closed until further notice. In the Browns Camp, Jordan Creek, Diamond Mill, Trask and BLM Nestucca Riding areas the gravel roads remain open for OHV use. We will let you know as soon as the trail closure is lifted. Please help us spread the word in the OHV community and, as always, feel free to call if you have any questions. Thanks for your help! Randy Peterson Recreation Program Manager Forest Grove District Tillamook State Forest 801 Gales Creek Road Forest Grove, OR 97116 503.359.7470 http://egov.oregon.gov/ODF/TSF/Recreation.shtml |
