Rear Window Question
Anyone running around w/ this window open? Does the headliner get all mucked up from exhaust like the 4Runners do w/ the window down? How about any bouncing around? A big negative, or not a big deal?
-bd |
I have tried the rear window open using a double ring latch, and carbiner to extend it but not go all the way open it was good around town but once you get to a high speed on open roads if you hit a bump it bounces pretty bad and has shut on me a few times
I've done it on real short trips around town but I think unless you have a side exit exhaust like the TRD you'll be seeing some fumes in the cabin, which we all know is bad.
How do you open the back window? I believe it opens up from the bottom but it looks like the spare tire is in the way.
I saw it, just turn key to left/right on the rear hatch door, it will open without touching spare tire.
| All times are GMT -8. The time now is 06:00 AM. |
