YotaTech Forums
-   93-98 T100s (https://www.yotatech.com/forums/f132/)
-   -   Check engine light and OBD1 and OBD2 ports (https://www.yotatech.com/forums/f132/check-engine-light-obd1-obd2-ports-307309/)
Otika999 Mar 24, 2019 11:11 AM
So i recently did a ton of work to my 1996 T100 SR5 3.4. I m currently getting a check engine with a very rough idle. I took it to a parts store but when they hoocked up to the OBD2 port it wouldnt talk to thier code reader, something about unable to get title or something like that. So far i havent been able to find anyone to read the OBD1 port in my area. So I tired the jumper trick to get the check engine light to flash =, well that didnt work. I honestly dont know if I am even jumping the correct ports or not as i am missing the over for the OBD1 port. Any help on this matter would be great.
BamZipPow May 3, 2019 12:14 AM
The 5vzfe is an OBDII engine only. Yer gonna need to check the OBD2 fuse in the fuse box to make sure it's not blown. Use a test light to double check the fuse is passing power. ;)
habanero May 6, 2019 07:06 AM
MTL 4runner posted this a long time ago- it really helped me-
J1850 VPW uses pins 2, 4, 5, and 16. Most American cars use J1850 VPW (as well as early Toyotas).
Pin #, Description
2 - Data (on my 96 the wire is White, goes to ECU connector)
4 - Chassis Ground (on my 96 the wire is Brown, check to ground)
5 - Data Ground (on my 96 the wire is White/Black, check to ground)
16 - Power (on my 96 the wire is Violet and is fused, 10 Amp)
https://www.yotatech.com/forums/f2/o...omputer-93580/
BamZipPow May 8, 2019 12:57 PM
The 1996 T-100 should be using the ISO9141 protocol fer OBDII. I believe that the 1995 T-100 used the J1850 protocol. I can't remember exactly sure what protocol the 1994 3rzfe engine based T-100 used. My 1998 T-100 uses the ISO9141 protocol. ;)
habanero May 8, 2019 02:08 PM
In case it's this one...from the link above
ISO 9141-2 Protocol Pins
ISO 9141-2 uses pins 4, 5, 7, 15 and 16. This is the most common type for non-US vehicles, especially Japanese models.
Pin #, Description
4 - Chassis Ground
5 - Data Ground
7 - Data
15 - Data (this pin is optional and may not be present)
16 - Power
Nathant100 Aug 8, 2019 07:21 PM
So my 1995 t100 3.4 built in February of 1995 has a check engine light on. I have tried jumping pins E1&TE1 together but my trucks engine light doesn’t flash at all, just constantly on. I have checked all fuses in the truck and they are good. Any ideas on why my truck doesn’t flash engine codes?
