YotaTech Forums
-   93-98 T100s (https://www.yotatech.com/forums/f132/)
-   -   ball joint spacers (https://www.yotatech.com/forums/f132/ball-joint-spacers-79862/)
tickt9842 Feb 28, 2006 04:46 AM
ball joint spacers
where can i get ball joint spacers, add a leaf , gears ( 529 ) and lockers for a good price???
Kookadala Feb 28, 2006 03:12 PM
5.29 gears? What size tires are you planning on running? You would want to be 37 or greater for that gearing. How about some specs on your truck and what you use it for. The more info you provide the easier it is to answer your questions.
Tacoclimber Feb 28, 2006 03:26 PM
What he said.
Tacoclimber Feb 28, 2006 03:27 PM
Originally Posted by Tacoclimber
What he said.
Oh yeah, and define "good price"....
tickt9842 Mar 1, 2006 12:51 AM
the 33x13.50 i have now rub pretty bad in the mud. i use the truck in the mud mainly. i want to get at least 35s. i have 4.30 gears stock. what gears should i go with and where should i buy them?? i know im going to need more lift other than the 4" trail master lift to fit the 35s.
Kookadala Mar 1, 2006 06:12 AM
To fit 35s you want a 4" suspension lift and at least a 2" body lift. My 35s still rub occasionally at full stuff when turning so I wish I had gone with a 3" BL. 4.88 gears match almost exactly for 35" tires, otherwise your speedo will be way off. Too much gearing can lead to broken parts.
Try to find a reputable shop that does gear work, unless you have done this before. There are 4x4 shops all over this country, but I have heard good things about Randy's ring and pinion, plus they always advertise in the Cal4wheel website so should be alright. Where do you live?
tickt9842 Mar 1, 2006 11:11 PM
im from north carolina but i live in gulfport ms because im in the military. ill be there for the next few years. we have an offroad performance shop there but the labor is a bit pricey. what gears do you have? do you have lockers front and rear??
Kookadala Mar 2, 2006 10:08 AM
I have 4.88 with ARBs front and rear. Very pricey!
tickt9842 Mar 3, 2006 01:14 AM
parts is the only thing thats going to get me. i have a friend thats been a mechanic for 25 years and he builds mud trucks in florida. all i have to do is buy him a case of coors light.
tickt9842 Mar 3, 2006 01:16 AM
with the set up you have now you havent had any problem with everyday driving or problems with your trany or transfer case??
Kookadala Mar 8, 2006 09:08 PM
No problems on the road at all. I did install a tranny cooler and do a flush to replace the fluid with synthetic. Nothing done to tcase.
Drive to baja or arizona with no problems, other then it starts to shake between 60 and 65, so gotta keep it 70 to be smooth!
http://www.webperception.com/jdougla...jpg/cooler.JPG
rocket Mar 8, 2006 09:23 PM
Originally Posted by tickt9842
where can i get ball joint spacers....
Click the link in my sig
t100 Mar 9, 2006 11:10 AM
i believe there is a place in mcComb that is still there, they put my bullbar and winch on when my dad first got it.. i will look it up and get back to you.. i will aslo ask some of my friends who lift trucks for a living and see what they charge..
bigbadktm Mar 19, 2006 07:41 PM
check out sdori for ball joint spacers.
