1995 T100 2wd Front rotor and bearing replacement
Just recently bought a 95 T100 2wd, 3.4, auto. I've done many brake jobs but noticed after reading that the T100's have to have the hub removed to remove the rotors. Can i replace the front wheel bearing without a press? I tried searching but couldn't find anything extremely helpful.
What parts would I need as well :
Rotors
Pads
Wheel Bearing
Inner Seal?
Outer Seal?
Am I missing anything? Any walkthroughs or videos?
Rotors
Pads
Wheel Bearing
Inner Seal?
Outer Seal?
Yes. The hub is just like any older style hub. Pull the grease cab and remove the spindle nuts and the hub and rotor will slide right off and the bearings will be right there serviceable. Get new rotors and pads, even if they have life left. They are seated to the rotors and changing just the rotors will make noise at best. When it comes to brakes, if you do one side you do both. Get bearings and new races to go with them.Bearings and races wear into each other. Plus if a bearing is bad then usually the race is too. There should be only one wheel seal. buy them. Get good grease and make sure you clean the hub completely of old grease. Not all grease is compatible
Shane8820
10-15-2016 01:28 AM
ColoradoRyan
06-28-2009 09:09 PM
KZN185W
05-13-2006 11:35 AM
surferfrank
9
11-13-2005 03:11 AM
Ilovemountains
10
10-21-2004 05:17 AM
