Wipers don't shut off
Ok, this has been a long standing problem. When the pavement is wet or it is raining, my wipers come on by themselves and will not shut off. I have to pull the fuse. Also, intermediate wiper control will not work. This may be a realated problem; the wiper washer will not pump fluid anymore. 97 Tacoma.
Your Wiper Motor Is Grounding Out "very Bad, Could Cause A Fire" You Need To Check Your Wires That Go To The Wiper Motor For The Probs With Wiper Delay & Washer Pump To See If The Wires Are Not Contacting Or Burnt/fused Together After Fixing Those Things Try To Seal The Wiper Motor Cover/wires With Silacone To Keep Water Out Of Wiper Motor Wire Contacts. Hope This Helps .worked For Mine."i Had Same Prob"
Originally Posted by TOYZILLA
(Post 50352646)
Water Was The Grounding Factor. Water Getting In The Wiper Cover And Getting On The Wires/contacts To The Wiper Motor. Far As The washer pump/wiper Delay They Had Got Hot And Burnt Together.so I Rewirerd Them And Now Work.
Originally Posted by Nimrod
(Post 50352644)
Originally Posted by toyota_mdt_tech
(Post 50352761)
Well, it can be either the motor or the switch. And yes, fix the wipers, you will fix the intermittent. The motor has a power source which moves it to a park position when you remove power by shutting it off. But usually this circuit goes open with wear, not closed. If I had to make a guess, I'd condemn your wiper switch. But a quick test with a test light can help. Turn your wipers on, and with a testt light, poke around to the 3 blue wires going to the motor. One should blink as its operating. Here is a link to the factory EWD. I have it on my ISP, so download it and let me know, then I will remove it.
1997 Tacoma Wiper/Washer Wiring Diagram |
(Post 50352960)
Ok, thanks I saved it you can remove it when you are ready. It is not the switch. I replaced the switch at first and still had the problem. It has to be a short somewhere, and I think it is down by the washer pump, but I haven't figured where or how to get it out yet. I have heard that it is inside the resivor. I think that a wire is shorting as it gets wet from road spray. This should help me track it down. Is the wires to the pump connected to the front turn signal wire package by any chance?
(Post 50352991)
Washer pump should be unrelated. If the wiper motor runs when its off and no intermittent wipers and we can completetly eliminate the wiper switch (you replace dit already), I'd guess the 2 wires going into the wiper motor, pins labeld B and S+ or pins #6 and 5, that these two wires were connected (shorted) together, then it would make the motor run on, even when off. There is a little cam that runs a switch. I dont think the cam looks like the picture, but the flat cover on the motor, remove it and you may reveal a problem that can be fixed without having to replace the motor itself.
