YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   Wiper issue.... (https://www.yotatech.com/forums/f131/wiper-issue-119473/)
nineball Jul 3, 2007 07:47 AM
Wiper issue....
So my wipers just quit working out of the blue, at first I figured the wiper motor had gone out, then on the way to the parts store they started working again. They will work for a minute then stop, I notice when i kicked the fuse box area they would come back on for a minute, I got stopped check the fuse it was of course still good and felt to be tight. Is there some type of module or relay near the fuse box, and if so what does it look like? I'm thinking that there is and it must be my problem, it is a 1990 model, thanks....
wraith Jul 11, 2007 05:22 PM
you may have a loose pin in your fuse box or a short in your wireing. pull your wiper fuse and get a T pin and see if your connectors are tight. if they are check the wireing, tho it's not out of the ordinary to have a bad wiper switch or a short in there too, just do some poking around, follow your wireing and just K.I.S.S. normaly thats all electrial problems are, simple crap.:)
