Rev Knob under glove box?
Dont know if this has been discussed before but i used search and couldnt come up with anything.
Anyways i was replacing my stereo yesterday and i noticed under the glove box there is a little knob that reads "REV High low" I turned it and nothing happened. What does this little knob do? Thanks-Blake |
Never heard of it... could be something the PO added for who knows what...
Originally Posted by elblako91
(Post 51045520)
4crawler always had all the answer.
my diesel has a idle up... not its by the steering wheel |
Originally Posted by 4Crawler
(Post 51045538)
That is called the "A/C Amplifier". What does it do? It sets the idle RPM below which the A/C is cut off.Works with the A/C idle up valve that normally boosts the idle speed when the A/C is running. Combination helps to keep the engine from bogging down at idle when the A/C compressor is running. All the above information is in the Factory Service Manual, A/C section.
Thanks 4crawler... my a/c was added after I got it and I have'nt noticed anything like that on mine...
