YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   Random wire (https://www.yotatech.com/forums/f131/random-wire-286070/)
Luke99tacoma Jan 15, 2015 05:21 AM
Random wire
Was putting a new battery in my 99 Tacoma yesterday and there was some random wore hooked to nothing just hanging there it looked a lot like the negative terminal wore but went to nothing... I can get pictures of yall need them but what should I do? 😁
JasonYota Jan 15, 2015 07:48 AM
Both ends are not connected to anything? Take it out then.
Luke99tacoma Jan 15, 2015 07:56 PM
the other end is connected to the negative terminal
wyoming9 Jan 15, 2015 11:48 PM
Did the wire some how break is there another end?? It corroded so bad it just broke off??
If it is doing nothing just remove it.
Odin Jan 16, 2015 01:24 AM
If it's real short someone might have added it as a ground to the fender. Nothing wrong with doing that.
JasonYota Jan 16, 2015 03:04 AM
I believe my old truck had that on the negative terminal, it probably grounds to the fender or somewhere close.
wyoming9 Jan 16, 2015 12:34 PM
I always run a ground cable to one of the inner fender bolts.
I wonder if it was a ground for some added after market device that was removed and just cut and left lay.:wrench:
