YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   Led tail lights (https://www.yotatech.com/forums/f131/led-tail-lights-290345/)
Scotttekoch 08-09-2015 02:13 PM
Led tail lights
Ok. I know somebody hear has the EASY answer for me....
1991 Toyota 4x4 pickup has 4 wires for tail lights
Brake
Left
Right
Marker
My new led tail lights have 3 wires
Ground
Marker
Turn / brake...
How the hell do I do this
wyoming9 08-09-2015 11:41 PM
:coffee: You don`t !! Unless you want to use a trailer light converter then follow the instructions that come with that to wire things up.
Toyota has the turn signal separate most others have all 3 in one bulb
I just use 2 separate lights one for the turn signals the other for the tail and brake light
AKHeathen 08-31-2015 06:09 AM
each side should have ground, tail, turn, brake.... a 5-wire system. as mentioned, you need a trailer converter if you are going to run 3 wires per side. do the tail lights come with a module or instructions?
