YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   Highbeams (https://www.yotatech.com/forums/f131/highbeams-89591/)
92foreruner Jul 6, 2006 08:09 AM
Highbeams
Hey I was wondering if anybody knew what the color of the wires coming of the highbeam switch was on a 92 4runner? I need to run a new power wire to it and there are a mess of wires I have searched online for diagrams but haven't been able to find any of the ones I need :dunno: Please help I'm tired of havin to hold the switch back in the flash to pass :(
92foreruner Jul 6, 2006 09:51 PM
Anyone??
4Crawler Jul 7, 2006 03:47 AM
You might have a problem with the headlight dimmer switch itself, see:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
92foreruner Jul 9, 2006 12:16 AM
Yeah it's a fuse problem but it has nothing to do with with high beams. I just want to know how to run power to the leads on the switch
4Crawler Jul 9, 2006 06:07 AM
High and low beams share a common power connection. Then the switch grounds the high or low beam filament to make it turn on. So if low beams work fine and the flash mode works fine, then the problem is likely the switch, as noted above. BTDT.
92foreruner Jul 13, 2006 04:34 PM
the fuse that seems to keep blowing is the dome light fuse under the hood I have checked the door pins already...but when this fuse goes my highbeams don't switch on but the flash to pass does :help:
