headlight ground
so if what I've read ,could you connect a lead to your ground coming off your low beam and groud it giving you day time runninglights????
ground
sorry 95 runner!
Well, you wound need power and ground to make the headlights/low beam to turn on. Power is normally supplied by the stock headlight relay and ground is supplied by the headlight/combo switch on the steering column. Might be able to get a 2nd gen DRL setup out of a Canadian 4Runner or get an after market DRL kit to add on.
| All times are GMT -8. The time now is 06:00 AM. |
