YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   ecu or not??? (https://www.yotatech.com/forums/f131/ecu-not-245501/)
edgewise Dec 2, 2011 02:03 PM
ecu or not???
i have an 88 4x4 with efi. somthing seemed to be going bad on it, the batt.& brake light would go on & off randomly or when turning corners then died all together while turning a corner & wont start. 2 shops including a toyota specialist said it was probly the ECU, i tried a 89661-35150 ECU but mine is a -35110.... can anyone tell me if i need the exact #? P.S. they both said the injectors are gettin power but not a ground. i cant find any shorts or breaks. i tried to fire it on starting fluid, not even a fart......
4Crawler Dec 2, 2011 08:56 PM
Alt./brake light:
- http://www.4x4wire.com/toyota/mainte...nator_brushes/
Injectors are grounded via the ECU, check the injector wire splices:
http://www.4crawler.com/Photos/Misc/...Wiring22RE.jpg
http://www.4crawler.com/Photos/Misc/...ctorSplice.jpg
edgewise Dec 5, 2011 07:20 AM
Thanks Crawler. This info is just what i needed. Hopefully I can check these soon. I learned a lot on here after I posted that. Seems to be a pretty common problem. Thanks agian. This site is priceless
