YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   Easy aftermarket reverse light set-up questions (https://www.yotatech.com/forums/f131/easy-aftermarket-reverse-light-set-up-questions-252734/)
TexFF Apr 25, 2012 08:15 AM
I bought a cheap pair of Optronics 4"x2" lights to use as reverse lights. They claim to be 55w each but I highly doubt that. I want to simply run a hot wire from each light to each factory reverse light wire and ground them individually. Can this be done without diodes or relays? I really don't want to mess w/diodes and relays mostly because I'm really electrical ignorant and I'm lazy! I'm not installing a switch. They will only be operated by putting my rig in reverse. If I do it the way I want, should I remove the factory reverse bulbs so there's less load on the factory wiring/fuse? Thanks.
waskillywabbit Apr 25, 2012 08:34 AM
Numerous lighting websites with diagrams.
Quit being lazy and search. :hillbill:
:wabbit2:
TexFF Apr 25, 2012 10:25 AM
:wabbit2:
Thanks but I don't need a diagram. I want to simply run a hot wire from each light to each factory reverse light wire and ground them individually. Can this be done without diodes or relays? If I do it the way I want, should I remove the factory reverse bulbs so there's less load on the factory wiring/fuse? Thanks.
90toy4x4 Apr 26, 2012 03:52 AM
Use a relay and power it from the fuse panel or expect to replace your reverse switch a lot. One relay is all you need. Takes all of 15 minutes.
