dash lights on 89 pick-up
the last bulb finaly burnt out on my intrument cluster, & I cant seem to figure out how to get to them to replace them. is there a trick to get to them ? my pick-up is a 1989, 5 speed, 4 wheel drive , 22 re. any advice would be appreciated
well, good question..you may reach up inside the dash from underneath, or just remove the whole cluster...I don't see other outputs of the situation
:facepalm:
- Remove the lower dash on the driver's side. (1) 10mm bolt and a few phillips screws.
- Remove the glove box/lower dash on the passenger side. (1) 10mm bolt and a few phillips screws. - Remove the radio bezel/center piece. Phillips screws. There is one screw hidden above the ash tray. - Remove the dash bezel. Phillips screws. - Pull the gauge cluster out. Phillips screws. You'll see the twist-lock bulb holders on the back. http://img839.imageshack.us/img839/973/0214091928.jpg http://img651.imageshack.us/img651/7026/0214091927.jpg http://img707.imageshack.us/img707/4814/0214091929.jpg The larger bulbs are 194s and the smaller ones are 74s. Also, if you have a tilt column, put it all the way down after you remove the lower dash...makes it easier to get the dash bezel out. Good luck! |
Dash lights 95 4 runner
i replaced the instrumentation cluster with led's and when i turned them on to check nothing, noda so i pulled them out turned them around nothing. then i noticed that the heater panel light is not working or the light in the shift lever so i check all fuses they are all good so then i put the old bulbs back in nothing. so then i took my test light and tried each bulb socket they have power to the socket and the power goes off when you turn off the lights. so every thing has power but new and old bulbs will not light up anyone know what's going on ?
Dimmer switch must be installed
Originally Posted by Chuck 2200
(Post 51859782)
Originally Posted by chicagopetedagreek1
(Post 51859495)
