YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   Buzzing relay when using right turn signal. (https://www.yotatech.com/forums/f131/buzzing-relay-when-using-right-turn-signal-305802/)
theragingrussian Sep 27, 2018 03:15 PM
I have a 1991 Pickup, 3.0 V6. Whenever I hit the right turn signal, the relay buzzes instead of clicking as it should. The left turn works normally and hazards click as it should. I have replaced the turn signal relay and opened up the combination switch (everything works there). I don't know if it is a wiring issue or if the problem is in the relay/fuse box/panel by the drivers feet. Whatever solutions you guys have would be greatly appreciated.
RAD4Runner Sep 27, 2018 10:00 PM
Most likely an issue with wiring on the right turn circuit. So between the relay the turn signal contacts and the bulbs, both front and rear.
Get a multi-meter.
Check all connections. Bare, shiny metal tightly against bare, shiny metal. Check both positive and negative sides.
theragingrussian Sep 28, 2018 07:00 PM
Thanks, will check with a multimeter. The front turn signal bulbs were exposed to rain (removed the bezels to work on the body and to replace headlight doors and grille) so could that possibly be a factor?
