YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   auto-off headlight modification? (https://www.yotatech.com/forums/f131/auto-off-headlight-modification-302268/)
xnor Oct 26, 2017 07:44 AM
I have a 1990 Pickup, 22r.
I want to modify it so that my lights turn off when I turn off the engine... last night I went to start the car after work and had left the lights on all day so I drained the battery. I've left the lights on a couple times now but luckily this is the first time I've done it all day.
Does anyone here have experience with a modification for this?
I'm wondering what terminology I need to look up. Are there kits or just simple modifications I can do for this?
Thanks,
Alex
wyoming9 Oct 26, 2017 02:41 PM
Are you sure ??
Just Power the Headlight circuit with Switched Power
I would need to look at the EWD for that year and model
Should be as simple as energizing the Head Light relay with switched power
Co_94_PU Oct 26, 2017 03:05 PM
Probably easier to just fix/replace the light reminder (buzzer).
old87yota Oct 26, 2017 03:13 PM
His truck probably never had one from the factory.
I know mine doesn't, but it is a 1987.
:safari:
xnor Oct 27, 2017 09:34 AM
oh huh, I hadn't thought about the buzzer. I do have a buzzer that sounds when I start my truck but it doesn't sound when I leave the lights on and turn the truck off..
wyoming9 ? Sure? you mean, am I sure that I want to do it?
old87yota Oct 27, 2017 09:45 AM
Let me clarify, I have a buzzer for leaving my keys in the ignition when you open the door but no headlight reminder buzzer.
My truck has never had a headlight reminder buzzer.
:safari:
wyoming9 Oct 27, 2017 12:16 PM
Yes are you sure you want to do this project ??
The only thing holding you back is your budget .
The tech is here to do this as sophisticated as you want.
I am sure with some thinking on your part you can make your lights do whatever you want
