YotaTech Forums
-   General Electrical & Lighting Related Topics (https://www.yotatech.com/forums/f131/)
-   -   Adding a Turn Signal? (https://www.yotatech.com/forums/f131/adding-turn-signal-142005/)
dieselloco427 Apr 5, 2008 03:13 PM
Are the front marker lamps supposed to be a turn signals in addition to being parking lights:think: ? I don't think they are on my 93 Runner, unless I screwed up wiring rebuilding the front end - would it be hard to add one into the fender?
This is kind of a safety concern that I have - not that people pay attention to turn signals anyway - but I'd assume that if you were approaching my truck at a 90* angle to the front, you would not be able to see my front turn signal on the bumper. I'm just OCD about some of these things I guess:)
DeathCougar Apr 5, 2008 03:25 PM
Nope, they are merely park/clearance lights. Several members have added signal lights into them, all you would have to do is run wires from the signal wiring to the parklight housing, and install a bulb setup, OR wire it into a 2 filament bulb (currently uses a 1 filament bult)
aviator Apr 7, 2008 08:17 AM
Actually on euro/aus spec trucks there is a seperate turn signal lamp that goes in the corner marker housing. If you look at the back of the lamp you can see a circular light hole usually not drilled out or else capped facing side ways below the main lamp socket. You could add a small lamp/socket unit there and wire it into the bumper lights if you wanted to.
I think the original lamp would have been a 194 size but I'm not sure.
dieselloco427 Apr 11, 2008 06:46 PM
I've noticed that before when I changed the bulb in the marker lamps. I'll take a look at it this weekend and see if I can get the socket at the auto parts store up the street.
