93 4runner Door Wiring Help
Ok so I need some help. I started wiring up quick disconnects for the wiring in my doors to take the doors off but keep power everything when the doors are back on. I found that there are a few wires with the same color combination. There are two with Blue wire, red stripe, and a red ring, and there are two with red wire, blue stripe, and a black ring. Does anyone know if these are interchangeable? Or does it matter which one goes where? If anyone could help that would be freakin sweet, Im not really a wiring guru.
ok looked over the wiring diagrams for the 4runner and cant find the wires u are talking about, but in any case u cant have them interchange or something will not work right or blow fuses. so mark then a little different so u know what ones goes with what. here is a link for the wiring section
http://www.ncttora.com/fsm/1990-1995...es/wiring.html |
Oh sweet thanks! I just decided what the hell, so i went ahead and soldered it all together, and everything worked perfectly fine so either the wires with the same color combo are interchangeable, or i got really super freakin lucky:rockin:
But I'm still gonna keep an eye on everything just in case |
