91 pickup - manual crank to power window questions
has anyone ever used any of the products that convert manual crank windows to power windows?
like
im curious how well they work before i buy them. and i want to know whether this will stop on their own once they reach the top and bottom? or could you potentially burn out the motor or strip the gears if you dont stop pressing the button?
also, why do some many people go the other way with it? power to manual that is.
like
Yeah that happens more often than it is pleasant to thing about..
It is a convince trade off do you want to be able to roll up a passenger side window while cruising down the highway without leaving over (crash hazard) versus knowing the window is going to operate reliable in almost any case that wouldn't have shattered the glass..
Kicking out laminated glass (windshield) is alot harder than you might expect, and shattering side glass with out the right tool is laughable at best..
Ever seen the videos of cops trying to open a side window with a baton or maglight? Wrong tool, place a screwdriver in the window jam lever and twist, a five year old can do it, try with a "safety hammer" you might get fatigued..
I have to think as glass ages it gets more brittle .
I broke two drivers side windows with my elbow just fishing for the seat belt learned that lesson after the ER trip.
Any Kit that says universal fit most often means lots of fabrication but after hours of work it will fit
Has anyone ever used any of the products that convert manual crank windows to power windows?
like these
I'm curious how well they work before i buy them. and i want to know whether this will stop on their own once they reach the top and bottom? or could you potentially burn out the motor or strip the gears if you don't stop pressing the button?
Also, why do some many people go the other way with it? power to manual that is.
like these
You could also install the factory power window system from a donor truck. If you have all of the parts from the donor truck, this would be the easiest because you know all of the parts were designed to fit your truck. If I had access to factory parts, that is the route I would go.
I think power vs. manual windows is just a personal preference, just like going with the 22R over the 22R-E; carbureted vs. fuel injection debate.
I like the simplicity of manual windows and you can roll them up and down at any time, even with a dead battery. However, I like electric windows because I can roll them both down anytime while I am driving and don't have to lean over to roll down the passenger side.
gary96360
09-19-2011 08:37 AM
MattTheCat
05-26-2010 01:06 PM
SteadFast
02-24-2008 05:59 PM
