80 amp fuse is blowing 92 22re xtra cab 4x4
i have a 92 4x4 xtra cab with a 22re my 80 amp fuse is blowing causing the alternator not to charge. i have already inspected all of the wiring under the hood, checked alternator, battery, all grounds and still havent found anything wrong. also i have no dash or brake lights and no power to the starter soleniod. any ideas on where to look next?
:coffee:Define Checked ?
When does the fuse Blow ?? |
New battery and alternator, cleaned grounds etc couldn't find anything visibly bad with wiring. It blows when I turn the ignition switch
You most likely have a short in the starting circuit .
Not sure if there are major differences in the pick up compared to the 4Runner I have the EWD for the 4Runner. can be in the ignition switch the clutch cancel switch or the clutch cancel start switch if it has one starter relay if it has one or the starter solenoid it`s self. it could also be in any of the wiring in the circuit. causing a short to ground a loose connection in the fuse block causing it to arc to cause a current draw overload You just need to take it one step at a time |
I have checked all of these things but I will check them again sometimes things are easy to overlook. Thanks
