2nd gen cluster removal
My speedo lights finally went out after a couple months of hitting the dash when they would go off. So today i tore the dash apart, i got the guages loose but i could not get them more than a half inch out due to the speedo cable holding it back.
I tried disconnecting the cable from the tranny but there is to much friction to pull it through at all. Does anyone have any tricks to getting it out easily? -Jack |
Disconnect the cable at the cluster. It has a connector similar to an electrical connector and will pull straight out of the cluster when the tabs are squeezed. The connector is fairly large compared to the cable (3/4" around), white, and round.
well thats my problem. i cant get my hand behind it to disconnect anything. But at least now i know what exactly is behind there.
:bump: anyone else?
