Programming a 05 Tundra Remote
This one comes from member nhparrott:
To add an additional remote on the DC factory system 1. Insert key into ignition key cylinder, then pull it out. (Assume from step 3 that driver door is open) Perform steps 2 & 3 Within 40 sec. 2. Press door lock control switch (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. interval. 3. Close and open driver side door Perform steps 4 , 5, 6 & 7 Within 40 sec. 4. Press door lock control switch again (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. interval. 5. Insert key into ignition key cylinder. 6. Turn ignition switch from LOCK to ON and back to LOCK at approximately 1 second intervals, 1 time (This sets ADD Mode) 7. Remove key from ignition key cylinder. Within 3 sec, Body ECU automatically performs power door LOCK-UNLOCK operation to inform which mode has been selected. (1 LOCK-UNLOCK) Perform steps 8 & 9 Within 40 sec. 8. Press LOCK and UNLOCK switches on transmitter simultaneously within 1.5 sec. within 3 secs of step 8 perform step 9 9. Press either switch for more than 1.5 sec. Within 3 sec,Body ECU automatically performs power door LOCK-UNLOCK operation to show whether registration has been completed correctly or not. LOCK-UNLOCK Occurs Once - Registration of recognition code has been completed. LOCK-UNLOCK Occurs Twice - Registration of recognition code has failed. |
| All times are GMT -8. The time now is 02:29 AM. |
