Painting Wheels (Video)
Article By:
<96 Runner> Supplies / Equipment / Safety Well ventilated area Stay away from open flames while painting Follow manufacturer recommendations for removing wheels/tires Organic vapor respirator Safety glasses Gloves Electric drill 3" Wire cup brush (fine) Sand paper (100 - 200 grit) Newspaper Durable painters tape (if tire is on the rim) Paint thinner or acetone Clean rag Quick-drying automobile primer VHT Polyurethane Wheel Paint (ideal, use 2 coats) Dupli-color High-temp Engine Paint (optional to VHT, use 2 coats) Dupli-color clear Wheel Coating (optional, but recommended, use 2 coats) Lug Nuts Follow the same instructions for the wheel if you want to paint the lug nuts. It should be noted, however, that powder-coating is recommended for lug nuts since, generally speaking, they see much more wear than a wheel over time. Wheel Weights Hand sand and wipe wheel weights with acetone or paint thinner. The primer step can be skipped for wheel weights. Paint can be applied immediately after quick-prepping the weights. Center Cap Follow wheel painting instructions for the center cap. Inside of the Wheel (back side) Same prep and paint rules apply for the inside of the rim/wheel. Be sure to remove all rust prior to priming/painting. Please note: On most wheels, the inside of the wheel is difficult to see when mounted, therefore painting it is usually a waste of time and money. Clear Coat Clear coat is recommended. However, it will make the wheel glossy (although the gloss uniformly fades over time). Touch Up (rock dings, scrapes, lugs, etc) Clean and dry the wheel. Apply a uniform layer of paint using the original color and type. Big Problems In the unlikely event that you mess up painting a wheel (for example a drip forms), simply lightly grind/sand down the effected area, wipe the entire wheel down with paint thinner or acetone again, and re-apply the paint. If the area cannot be fixed, repeat the wheel prep and painting process from step one. Christian has chosen to include a step by step video here. The video is hosted on You Tube. Click the picture to view it. Once there, you can also watch the video full screen by clicking the far right button on the player. https://www.yotatech.com/~tech/you_tube.gif The video is also embedded on this page here if you would like to view it inline with Christian's text above. <object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/q5eK5OnHfqA"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/q5eK5OnHfqA" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object> Any questions about this article, please contact <96 Runner>, and not Writeups@YotaTech |
