YotaTech Forums
-   Appearance (https://www.yotatech.com/forums/f126/)
-   -   Custom Grille Insert - 3rd Gen 4Runner (https://www.yotatech.com/forums/f126/custom-grille-insert-3rd-gen-4runner-75822/)
Bob_98SR5 Jan 8, 2006 05:28 PM
By Jacksonpt
Here is basically what I did:
- removed the grille
- used a dremel to cut out 'center section' of the original grille, leaving behind only the outside chrome edge.
- laid the grille on some super thick, very rigid cardboard (it's what I had laying around... but wood would probably be better) and traced the inside edge.
- I then cut out the cardboard to form a "mold" of the inside of the grille.
purchased gutter guard (super cheap at Lowe's) and formed the gutter guard around the cardboard mold. I left a slight overhand around the edge.
- drilled a few small holes around the inside edge of the grille.
- laid the formed gutter guard in the grille
- used zip ties to attach the insert to the holes I drilled (see right pic below).
Then just clean up your mess... took me about 2 hours (3 hours including trips to Lowes for the gutter guard and Sears hardware for zip ties)
Total Cost: about $4 (slightly more if you buy wood to use for your mold). Not very difficult, just pretty tedious.
https://www.yotatech.com/~corey/tech...ptied-full.gif
https://www.yotatech.com/~corey/tech...rille-full.gif
