Cup Holder Mod
As promised I have added the Cup Holder Mod. I want to thank Bob_98SR5 for his original mod and the details it provided. I tried to find it to reference it here but the link seems to be dead. I will edit this write up if I get more information.
The original write up was for using the stock OEM parts from the first flight 3rd gen 4runners and was an EXCELLENT starting point for me. I opted for more of a 'plug and play' concept. Bob also relocated his switches from the 98 console to his drivers dash utilizing the OEM cutout mounts. Super idea but I have future uses for mine so decided to relocate those items to the shifter console. The dreaded Flight 1 OEM configuration https://www.yotatech.com/~tech/Ritzy...lder_mod/1.jpg My '98 SR5 had the Toyota security system installed along with the Rear Window and ECT select switches which would need to be relocated. Viewed from the passenger side https://www.yotatech.com/~tech/Ritzy...lder_mod/2.jpg NOTE: It is not necessary but I removed my seats to better facilitate removal and installation of the center consoles. This can be accomplished with the seats installed. First order of business is to gather up the parts and tools. Basic hand tools that you have on hand will do just fine, no special bits or service aids. #2 Phillips 10 mm socket 12mm socket Ratchet handle 12” extension to clear the console bucket. Utility knife w/ sharp new blades Diagonal pliers 10 mm open end wrench Channel lock pliers Dremel with cutter and saw blade Jig saw Med point sharpie 120 grit sand paper Small wire ties Plastic adhesive From a 99-02 4runner: Center Console Center console mount plate e-brake handle assembly e-brake tub (not required but nice) I would recommend that first set the e-brake as high as it will go. If your vehicle is a 4x4 place the 4x shift lever forward and remove the handle. Remove the Center console attachment screws located just aft of the shifter console, one on each side. https://www.yotatech.com/~tech/Ritzy...lder_mod/3.jpg Remove the two console bucket bolts using 10mm socket and extention https://www.yotatech.com/~tech/Ritzy...lder_mod/4.jpg If equipped with a rear heater, remove the heat selector knob. It will just pull straight off. If you desire you can remove the rear window switch and the ECT switch (if so equipped) . Pop the two switches out and find the small release tab for the connector. Press the tab down and pull the switch from the connector. https://www.yotatech.com/~tech/Ritzy...lder_mod/5.jpg https://www.yotatech.com/~tech/Ritzy...lder_mod/6.jpg Grasp the console with both hands and it should slide backwards enough to clear the heater control lever. Lift slightly and push forward. You will need to rotate the console to clear the shifter on an Automatic. (That’s another reason I removed my seats). You will still have your switches connected so be careful when you twist the console to remove it. Beneath you will find the connectors. Most of Toyota connectors will have a tab for you to depress to release them. The two small connectors for the Toyota security system are PITA. You will need a very small flat tip screw driver or a small awl. I inserted a large jewelers screwdriver into the connector where there is a small ridge, lifted slightly and the connector was easy to pull apart. Took a few tries to figure out the best way to get it free. The first connector under the console to release is the rear heater fan control wire. https://www.yotatech.com/~tech/Ritzy...lder_mod/7.jpg Next find the Security connectors and disconnect them. https://www.yotatech.com/~tech/Ritzy...lder_mod/8.jpg Now that the console is free remove it to the side. We can now see the e-brake mounting in the e-brake tub as well as the console center mount. https://www.yotatech.com/~tech/Ritzy...lder_mod/9.jpg Just forward of the e-brake bracket is the electrical connector for the e-brake. Disconnect this wire. Make sure your wheels are chocked and release the e-brake. Remove the two mount bolts for the e-brake bracket. https://www.yotatech.com/~tech/Ritzy...der_mod/10.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/11.jpg This will free up the cable and provide you direct access to the e-brake retainer clip. Using a flat bade screwdriver, bent the retainer slightly open enough to allow the cable to come out of the cable groove. https://www.yotatech.com/~tech/Ritzy...der_mod/12.jpg With the cable loose, use your channel lock pliers and 10 mm wrench and loosen the top lock nut on the cable. Once that is removed the second nut will easily spin off. Try to make a note of the distance down the cable where the nut is located. This is the adjustment for the e-brake. https://www.yotatech.com/~tech/Ritzy...der_mod/13.jpg The e-brake is now ready to be set aside. This is what the two e-brake brackets look like side by side. The ’98 is to the left and the ’00 is to the right. Notice that the forward bracket mount is longer. Toyota used the in place mounting points for both e-brake brackets. https://www.yotatech.com/~tech/Ritzy...der_mod/14.jpg Next you need to determine if you are going to mount your switches in the drivers dash area or relocate them to the shifter console. I chose to mount mine in the shifter console so the remaining portions of this write will be dealing with that install option. Next you will need to separate the wire bundles. Toyota usually binds them in plastic sleeves and wire ties. Once again you need to decide how you are going to route your wires for the switches. Find the wire ties and using the diagonal pliers, cut the wire ties off. Be careful not to cut your wires! https://www.yotatech.com/~tech/Ritzy...der_mod/15.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/16.jpg Now begins some serious modification. Using both the old console and the new console, you will need to mark the edges of the new console with the base edge outline of the old console. There are differences between the contours. Lay the old console against the side of the new one. Line up the top edges and ends of the two. You will see the ‘99+ will be taller then the flight 1 console. You may need some assistance with holding the two together. Use a marker and trace the bottom edge of the old console. Do this to both sides. They should be very similar. https://www.yotatech.com/~tech/Ritzy...der_mod/17.jpg Now you will be at the point of ‘no return’. Using the jig saw with a medium tooth blade, cut the edges off both sides and trim up using your utility knife leaving a nice clean edge. https://www.yotatech.com/~tech/Ritzy...der_mod/18.jpg Remove the console bucket from the console as you will be doing some modifications to the support ribbing so it will fit over the center hump and allow you to secure it in place. Here is what they look like next to each other. https://www.yotatech.com/~tech/Ritzy...der_mod/19.jpg As you can see the two buckets are different in both size and construction. https://www.yotatech.com/~tech/Ritzy...der_mod/20.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/21.jpg There are numerous support fins along the bottom of the bucket. You will need to identify the ones that impair the placing of the console on the center hump. What I did was to mount the new center bracket and then use the console bucket and line it up with the mounting holes. You can see where you need to trim away plastic fins in order for the assembled console to mount properly. Just take your time and trim away all obstructive flanges and fins. https://www.yotatech.com/~tech/Ritzy...der_mod/22.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/23.jpg Once you have a completed bucket reinstall it in the console. Next we are going to begin the mod of the old center console switch mounts for placement in the shifter bezel. The OEM configuration for the ’96-’98 had 4 locations for switches, two on either side of the e-brake. https://www.yotatech.com/~tech/Ritzy...der_mod/24.jpg The underside of the console shows the support fins for the switch mounts. When I removed the switch mounts I trimmed the underside support fins off but in hindsight, I should have left them intact as they are useful to mounting the switches and helping to keep them in place. My mistake will help you! https://www.yotatech.com/~tech/Ritzy...der_mod/25.jpg Using a Dremel tool with a metal cutting wheel, I begin by cutting the outer edge of the switch mounts. Leave about an 1/8th of an inch around the mount until you free the mounts from the console. https://www.yotatech.com/~tech/Ritzy...der_mod/26.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/27.jpg Separate the mounts into individual mounts and trim the edges. https://www.yotatech.com/~tech/Ritzy...der_mod/28.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/29.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/30.jpg I needed to mount three switches in my shifter bezel, the Toyota Security Indicator, the ECT switch and the Rear Window switch. The two actual switches were the challenge. The longest being the ECT. There are several locations that these would look really cool on the shifter bezel but you need to remember that there are mechanical impedances along with wiring under that bezel and space is minimal. Check clearances carefully. I finally ended up with the ECT switch near the top left corner, the Security ID sideways in the upper right corner and the window switch near the back edge, also sideways. The ideal location for the Window switch was going to put it over the snap down of the shifter bezel so I had to move it slightly. Once again, be sure to check for enough clearance BEFORE you cut the holes! Take the switch mount and lay it in the selected location. Trace out the inside of the switch mount on the bezel. Make this outline again about 1/16th of an inch around the outer edge of your first trace. Using the utility knife, make a scratch mark along the tracing. Continue remarking with the knife until you begin to cut through the plastic. https://www.yotatech.com/~tech/Ritzy...der_mod/31.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/32.jpg Trim the opening and then trial fit the switch mount. https://www.yotatech.com/~tech/Ritzy...der_mod/33.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/34.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/35.jpg One other thing to remember when you cut out the switch mounts, the switch mounts have notches in them. This is so the switches will mount in one direction. Remember this or you end up trying to shave the switch to make it fit correctly. https://www.yotatech.com/~tech/Ritzy...der_mod/36.jpg Trail fit the switch to ensure a correct fit. Make adjustments until the switch snaps in to place. https://www.yotatech.com/~tech/Ritzy...der_mod/37.jpg Mark and cut out the remaining opening for as many switches ad you need to mount or can fit into the shifter bezel. I had to use a plastic adhesive to hold the switch mounts in place. I attribute this to removing the switch mount support fins during the cut out phase. If you leave some of the fins, the switches may snap in completely all around and hold the mounts in place. I just didn’t want to have them popping loose at the wrong time, so securing them with adhesive is recommended. Set this aside for at least 12 hours or at least overnight. When mounting the ECT switch in the upper left location, I had to remove a plastic cover mounting which was where two connectors were located and fixed in place to prevent movement under the shifter bezel. The length of the ECT switch necessitated this modification. It was difficult at best removing them which also required removing the mounting clip for another connector. These can be relocated under the bezel to prevent movement and accommodate the switch. You can then move and reattach the connectors using small plastic wire ties. Once you are satisfied with the install of the switches, remove them, slip the shifter bezel over the shifter and 4 WD selector lever, routing the connector wires through their appropriate mount, snap the bezel into position, install the lever knob, attach the connectors to their respective switches, then snap them into position. Test the switches for proper operation and your done! https://www.yotatech.com/~tech/Ritzy...der_mod/38.jpg https://www.yotatech.com/~tech/Ritzy...der_mod/39.jpg Hope this helps anyone who is contemplating this mod. I will be happy to answer any questions you may have. Enjoy! |
