YotaTech Forums
-   Alarm Systems (https://www.yotatech.com/forums/f124/)
-   -   Factory Anti-Theft won't chirp (https://www.yotatech.com/forums/f124/factory-anti-theft-wont-chirp-133339/)
terminator Dec 28, 2007 05:26 AM
Do you all know how to make the factory anti-theft chirp? I'm guessing there is a way to enable/disable it.
blarchitect Jan 3, 2008 02:56 PM
Most likely Piezo chirper next to battery is dud, or prev owner disabled it, if it never chirped. What model is the alarm?
terminator Jan 3, 2008 03:55 PM
Worked before the engine swap, everything looks to still be attached. There seems to be a fuse inside the driver kick panel that I'll check tomorrow when it's light. How do you tell which alarm it is?
Thanks
Jason
yotasavg Jan 3, 2008 04:05 PM
i'm not sure if mines aftermarket or not......i'd be interested to know how to tell the model also. sometimes mine won't blink the lights but it always chirps.
terminator Jan 3, 2008 05:03 PM
I'm positive mine's factory, I'm hoping just the Piezo is bad and can be ordered.
blarchitect Jan 4, 2008 11:06 AM
Well the obvious way to tell if it's factory is by the fob. Should have toyota emblem. As far as I know there are two types the rs3000(which I have. Coffin shaped black fob) and rs3200. Former has two buttons and the latter three.
blarchitect Jan 4, 2008 11:10 AM
Heres a link. Is this the fob you have? Scroll to foot of page
http://4runners.org/writeups/rs3000/index.html
terminator Jan 4, 2008 11:31 AM
Yep, guess I have the RS3000. Thanks for the link too, I have two extra remotes coming so they'll need reprogrammed.
Jason
terminator Jan 4, 2008 05:42 PM
Well the extra remotes were a bust, idiot said they're from a 96 T4R but failed to mention an aftermarket unit. Oh freaking well.
Thanks to everybody for sending info on the piezo, RS replacement worked out perfect this evening. Works like new now.
Jason
