Where to buy ARB lockers and gears
I've decided to do ARB's and 4.88's.
I believe I'm going to need the lockers, compressor, gears, install kit for the gears (bearings, seals, diff gasket), and diff oil. Do I need anything else like air hose/fittings for the lockers? What brands of gears are good or should I avoid? Anyone having specials or particularly good prices on ARB lockers and/or gear sets? These are the places I know about... PORC trdparts4u 4 Wheel Parts (free compressor + free shipping right now) |
i got my gears from PORC and my lockers direct from ARB.
i'd suggest yukons for gears and master install kits, and then either trdparts4u or PORC for the lockers. the gears w/ the master install kits have everything you need. the arb's with the compressor will have everything you need. |
I was going to do the exact same setup. After many hours of research, the best price i found for everything was at www.dunksperformance.com
It is somewhat of a Catch-22.
PORC and the Texans have smoking deals (See this Phil, positive press) and usually good stock. Problem is most shops will tell you to take a hike if you walk in with parts bought elsewhere just in case there are problems. |
yeah, it's not always about the cheapest parts- that's for sure.
i was lucky enough to have a small-town race shop set mine up. the owner has done thousands of gear sets, and owned a 1st gen runner, so he'd also seen his fair share of the insides of a toyota housing. he did my rear ARB initial install, and then did the regear. however, he didn't have the correct dial indicator to do the front, so i had a toyota tech from a local dealer do it on his time over a weekend. he did an ARB install w/ a regear - basically new everything into an existing shell. the rear was $150 each time and the front was the same. that was for bench installs into "cores" that i got. once they were on my rig, i then sold my originals to get some money back for the "cores". if you go to an offroad shop, they'll want to sell you the parts or tell you to hit the road - more than likely anyway. don't forget that you can also get thrids and diffs from randy's that are already set up with lockers and gears. you'll have to check w/ them on price. |
I try to avoid giving 4WP money of mine. If you are going to pull thirds, get the ARBs from Strap 22 and have at it.
Lamm |
A good 4x4 shop will do the install even if you bought the lockers else where, especially if you just bring in a 3rd. PORC has the best deal on gears I found.
x2 on not giving 4wheel parts the sale. Go local or find a vendor on this board. |
Yeah, I hear what you guys are saying about 4WP, but free compressor + 10% off for President's day + free shipping adds up to $$$$$$$$$$$$$$$$$$$$$. Of course, you're getting Genuine Gear instead of Yukon, and from what I've read, that's a significant drop in quality...We'll see how close others can get with the higher quality gears.
Install's not a problem - similar situation to bamachem. I will be taking him the thirds. |
do NOT get Genuine Gears. RUN!!!!!
4WheelParts
R&P+Locker pkg w/ Upgraded compressor TOTAL: $1895 PORC: Gears and install kit:$ 510 Lockers: $1378 Compressor: $ 199 Shipping (est) $ 40 TOTAL: $2127 Dunk's: Gears and install kit:$ 537 Lockers: $1470 Compressor: $ 205 Shipping (est): $ 40 TOTAL: $2252 |
Hi TC....I've had many good dealings with PORC http://performanceoffroadcenter.com ask for Cody if you call them up.
Dunks has also treated me good. I'd like you to think more carefully about your gears....Yukon is just fine...Genuine is garbage. When I'm on the trail, I myself want my gears to be one of the strong points of my driveline....that does not mean I have to do dana60. It means a pro install....any gear ratio....410 all the way to 571. By the way, I would put my 571 gear install up against any 410 install and probably bust the 410 all to hell...knowing what I know about tooth contact and leverage. ;) ZUK |
Actually, PORC's price on the locker setup is even better than trdparts4u (who doesn't do gears coughPhilcough LOL)
Thanks for the advice everyone - It sounds like the extra $232 to buy from PORC is worth it... |
Originally Posted by rocket
Phil don't list gears (just like Dunks don't list ARBs) but he does sell them.
hmmm i'm not sure. A few months ago i was given a quote for Yukon gears from Barb (TRDparts4U) so your guess is as good as mine. :think:
TC - I know it's a haul for you, but I had Otter (Whaley Enterprises) in Harrisburg do mine. I ended up having the gears and lockers drop shipped to him and bought a front pig and rear 3rd to have setup so I'd have no down time.
If you have an Auto and 4.88's, you will be able to sell the setup 4.88 3rds. |
We sell these packages at this price everyday. Some days we win some days we lose. If PORC can do that price I say go for it. We have had great dealings with them and we do refer people to them. We tried selling gears too but decided to stick with what we know........ARB/Toyota's
