What is broken on YOUR Toyota
Old 07-10-2017, 01:33 PM
  #1261
Jacobfarms's Avatar
I'm trying to haul stuff and my o/d off does not work at all. The button on the shifter clicks like it's suppose to but I get no light and when I'm driving and o/d is in the off position it still goes into o/d any ideas about what I should be checking????
Old 07-11-2017, 01:35 PM
  #1262
Bojangles's Avatar
Its will to live
Old 08-28-2017, 04:08 PM
  #1263
Dielawn's Avatar
There's a clicking noise coming from my clutch and I'm super scared the little clip feel off the throwout bearing. That means dropping the transmission again and I just installed the new clutch. Shifts fine though.
Old 08-29-2017, 06:56 AM
  #1264
SomedayJ's Avatar
Antenna mast, rear bumper end caps, exhaust has to be replaced... I'm sure this list'll increase...
Old 08-29-2017, 07:55 AM
  #1265
fasterspider's Avatar
The climate control levers are all busted up and do not work at all, no defrost in winter is a drag.
The tailgate that I already replaced once needs to be replaced again due to motorcycles bending the inside surface to the point it the latch doesn't work again. Latches are cheap and $92.00 for a tailgate isn't all that much but, I don't have $92.00 to just throw at a tailgate again.
I put too much lift in my truck to load anymore motorcycles, ain't happening again but, my ATC will go in the bed again.
Old 08-30-2017, 08:24 PM
  #1266
mikesnyhere's Avatar
Unhappy the short list
spring bushings , trans is howling can't even use 5th , intake boot is electrical taped . battery hold down is rigged up ,back window needs jumped out to open, frame is cracked at steering box ,drivers knuckle is welded at steering arm, all the tie rod boots are torn ,rigged up bolts holding the trans crossmember to frame , windshield is cracked ,only 1 headlight works ,and thats just what I can think of ...then there is the other one !! and the other ,and my wife's .. good grief I need to hire people .
Old 08-30-2017, 10:45 PM
  #1267
thebluecondom's Avatar
storys 4 the big boys
91 Pickup V6 3VZE Checking In--
Previous owner took out the battery restraint so the power steering belt dug a hole in the battery and the fluid dripped onto the lines underneath. Not a big deal in all actuality. Crooked fenders and an offset (replaced) front bumper. Replaced because I crashed Into a fence, and I swear to whatever god you pray to that the truck ran better after. Collisions do not effect this truck. Dented door and missing AM/FM antenna from when some hater at the strip club smashed up my truck with a 2x4 and drank all my liquor! On my birthday! Not cool! I decide to be "responsible" and walk home. Next time I'll push the truck thank you very much!!! Right now it's the engine that's not working. Right when you think the thing couldn't go any slower... BAM! You just turned that 3 point slow into a 3 point no. But it hasn't seen it's last days. Every kilometer on this vehicle is equivalent to one good time and I plan on having many more. Thanks for listening to this sad prude babble...
Old 09-02-2017, 11:35 AM
  #1268
hikinout's Avatar
Need to put on an a new used tranny, and a new exhaust manifold. Also...someone filled my truck with ants while I was out of town, so...
Old 10-10-2017, 07:31 PM
  #1269
ToolTyme1's Avatar
ALternator doesn't get signal to charge
I've got an 84 SR5 4x4 truck and I have 2 good alternators and two good regulators that I've been trying. I can't get it to charge. Which wire is it that isn't doing it's job? Is it an ignition switch problem? This is apparently a mid year truck where it could have had any of three different alternators. Toyota can't tell me which one for sure, even with the VIN.
Any takers????
Old 10-10-2017, 07:34 PM
  #1270
ToolTyme1's Avatar
I have another wiring question. How do I hook up a 4-flat plug for trailer lights that will allow the brake lights and the blinkers to work on a 1984 Toyota truck? Seems to me that years ago the was some kind of conversion box the we had to use, but I can't seem to find anyone out here that knows anything about it. Any help will be appreciated.
JC
Old 10-10-2017, 07:40 PM
  #1271
ToolTyme1's Avatar
I have an extra Toyota transfer case that I would like to piggy back onto mine. I see people have the Marlin setup but is it possible on mine with some sort of adapter? Is there a shop in AZ that anyone would recommend I contact about this?
Old 10-10-2017, 08:18 PM
  #1272
Go to Marlin's site and check it out.
https://www.marlincrawler.com
They sell adapters to mate up two transfer cases or whole dual t case set ups like I have in my 85 Xtra-Cab.
Old 10-10-2017, 09:08 PM
  #1273
ToolTyme1's Avatar
Were you able to just use a one piece drive shafts after the conversion? I hate that carrier bearing on mine.
Old 10-11-2017, 04:43 AM
  #1274
Yes, I have a nice and heavy duty one piece shaft out back and a Marlin Crawler long spline up front.
Old 10-19-2017, 06:07 PM
  #1275
thefishguy77's Avatar
Possible a head gasket or motor
Fired it up yesterday to warm it up. Got stuck inside for about 15 minutes. Came out gauge is touching the red and no heat in the vents. Water all over the TPS/thermostat area. Rained nonstop today so I didn't want to stand in the rain diagnosing a cooling problem. Hoping i got lucky. Just replaced the t-stat and must have not torques a bolt down. It a completely rebuilt motor with under 30,000 on it.
Old 10-19-2017, 07:47 PM
  #1276
RAD4Runner's Avatar
A problem well-stated is a problem almost solved.
How do you know the battery is not charging?
How do you know you have two good alternators when neither is charging the battery?
Got a Voltmeter?
I have a 22R-E so I'm not sure if your truck's schematic is same as mine. Anyway, this post (https://www.yotatech.com/forums/f199...l#post52094780) shows pin-outs of the alternator.
Check voltages at 'IG", "S", and "B". Don't worry about "L' yet. Let us know what you find.
Old 10-20-2017, 12:10 PM
  #1277
Angry oh boy !
add 529 front gearset to my list ..... YIKES chipped teath ! PO welded the hi steer arm to knucle too ! what a PIA to get it off . can anyone say six shooters !!!! and chromoly axles ! yes . may as well do the ifs hubs tacoma brakes too ... dam this list keeps getting longer
Old 10-20-2017, 06:13 PM
  #1278
aa1911's Avatar
driver door key lock cylinder.... have to crawl in through the passenger side for over a week now, not cool.
Got a new key cut at Toyota for $10, no dice. I could fiddle around with the cylinder and possibly 'fix' it but just ordered a whole new lock set for $287. Includes ignition, two door locks and a third door lock for the fuel door. Boomsauce. Can't wait for like new locks!!
And the speedo went out on the 4runner.... among many other things on it. But it still runs after 24 years original so can only complain so much.
Old 06-01-2018, 11:17 AM
  #1279
mrcocoa's Avatar
Cluster lights. Have been out for a year driving me nuts.
Old 06-22-2018, 09:46 AM
  #1280
fidoplank10's Avatar
Lumber Rack = Metal Fatigue
Recently purchased '96 T100 with Ext Cab. Prior owner had a lumber rack with 6' hang over the cab. Oscillation and vibration created metal fatigue on the front corners of the bed and broke the mounts. Got it rewelded, but the ride still has vibration. Time for new shocks. Other than cruising the beach at low tide, I don't plan on serious off-roading. Opinions on KYB stock shocks for mainly highway use?
Quick Reply: What is broken on YOUR Toyota
