Theft Recovery Ideas/ Anti-Theft ideas
I just saw some punk kids walk by my truck, and look in the windows. It got me thinking about my truck getting stolen. If they found my kill switch, and started the truck they would be pretty much home free to get it to a safe spot and strip it before I even found out it was missing.
My idea: Install a kill switch on all lights. That way they would get pulled over for no headlights if dark out, no brake lights, no turn signals, etc. Hopefully this could lead to a vehicles recovery. What do you guys think? |
sounds like a good idea to me. just hope they dont crash it
wait what exactly is a kill switch?
Originally Posted by algranger
(Post 50615217)
o, sound good to me
Might work, but then what if they only drive a few blocks and then tow it? I also think that would be a big anoyance everytime you leave/enter the vehicle, all those switches everywhere...
(Just playing devil's advocate) |
Originally Posted by Pest
(Post 50615246)
Here in Spokane, alot of drivers drive with no lights on. Sooner or later I guess the coppers would pull em over.
Another Kill/Lockout switch on the neutral safety start switch would work. |
Instead of all the lights, you could just do a Killswitch on the ignition, then one on the fuel pump. That'd stop them from even leaving unless they found both switches. Or be super sneaky and have 2 switches on the same line.
I've heard of people taking out their EFI fuse or something to that extent...
Originally Posted by 89silverpu
(Post 50615295)
Thats a bad idea because you are resetting the ecu when you do that. Then it has to learn all over again. |
I dunno, had no issues with the EFI fuse removed.
I personally feel a fuel and ignition cut off works the best, install the switch somewhere odd no one would look. I wont tell you where I have hidden them but its in a way outta the way place. |
Originally Posted by CJM
(Post 50615338)
Originally Posted by Kaleb
(Post 50615334)
a dead battery, no gas, and 3 flat tires are doin the trick with my truck :hillbill:
but once i get all my mods done, i'll probably run a push button starter hidden somewheres, my dad had a bronco that had one, it got broken into, and the ignition popped, but they couldn't get it started! :bigok: love those things |
Originally Posted by 881stGenRunner
(Post 50615365)
So everytime you start your truck you have to hit your switches right?
I personally pull the EFI fuse, simple and effective. |
One of my buddies has a headphone jack right below his ignition. He uses a headphone plug as a key which completes his fuel pump circuit. I thought that was pretty cool. I might do that sometime down the road.
Alarm with an iginition kill works for me. Truck's been parked out front for eight or so months. The Camry that used to be in it's place was broken into 4 times in 3 years. Nothing was ever stolen though, just busted locks.
Shouldn't one well hidden "kill" switch be enough agains "punk thieves"? I guess that 2 switch hooked in series would be very hard to defeat as they cycled there way thru all your driving light and accessorys. What are your guys thoughts on "types" of kill switchs.
Do you guys like the style that kill it dead/wouldn't let it start at all, or one that lets vehicle start {making them thinking there going to get away} and then it dies after a few seconds in a conspicuous spot or position? |
