Starter (fell out) Need Size Bolts for 84 4x4 22r motor...?....
This is the 22r carburated truck.
I checked my shop manual , it says nothing, went to checker , they have no idea....
Help appreciated much....................
Hey Bud Im having the exact same problem lol!!! I think its a 10mm thread and then just the length of the threaded hole in bellhousing. Im just waiting to see if anyone gives us any feedback so we know exactly.
Good luck man!
Good luck man!
Bolt part #9161261030 $1.20
Stud part#9011610021 $1.63
Nut Part #9017910132 $1.11
Try your local dealer.
I called my local dealer and they didnt have any in stock either,nor did they have the dimensions.
I have found some sources say any from '84-'88 and other sources say '84-'90 will fit.
Sounds like its time for a trip to a wrecking yard.
Unfortunately thats probably going to be the case...for me anyways. Im still avoiding it though because there is a ton of snow on the ground and the weathers warming up a bit so its all turning to slush lol
You might find the bolts at your local autoparts dealer or not.
Your toyota dealer more than likely can get the parts over night at least mine can
It is a M10x1.25 thread pitch . not sure of the correct length but by eye i would say 45 to 50 mm. Of course the nuts are the same size M10x1.25
if you drive toyotas you should have some extra hard ware just for these projects.
Hope that helps
Hope that helps
Great Information, Thank you so much. I own a 1983 P/U short bed and I am always trying harder to find the proper parts. I do not mind going to the" yards" , sometimes the yards are very short in parts as well. But for sure I won't give up my truck.
Thank you for the great help I appreciated
Mr. D
Mr. D
09-04-2015 09:27 AM
ZONAYODA
07-13-2015 07:17 PM
