New Motor Break In Time
Old 10-11-2006, 11:39 AM
keithguts's Avatar
OK this is the deal, I'm having new HG's, Valve Job, Timing Belt, and new Waterpump in my rig. My question is, do I have to worry about break in time for this job on the engine? If so, please explain. Thank you all.
Old 10-11-2006, 11:41 AM
millertime_t1's Avatar
No -- you should be fine !
Old 10-11-2006, 11:48 AM
MonsterMaxx's Avatar
Best thing to do with a new motor is run it at 2000-3000 rpm unloaded or lightly loaded for 15-20 minutes to let the moving surfaces burnish.
Then run the piss out of it, harder you run it the better the rings will seat.
Of course, you want to make sure you aren't having lubrication or cooling issues before running it hard.
Old 10-11-2006, 12:29 PM
Bumpin' Yota's Avatar
and if the bottom end hasnt been touched? Just the top end worked over? Do the same thing and change all fluids?
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: New Motor Break In Time
