Need help dianosing a problem
car stalled going 65 MPH, It jerked and hesitated for a couple seconds, then shut down.
Pulled a number 12 Code: "RPM Signal" what does that mean? Trouble area: Distributor circuit, Distributor, Igniter Circuit, Igniter, ECM How can I check these areas? My Haynes just tells me how to remove them, not how to test them. The vehicle is not getting spark, I tested the Coil and it was within the recomended resistance (BUT JUST BARELY). so that shouldn't be teh problem.... Any HELP IS APPRECIATED? Vehicle 94 toyota Camry 4Cyl (5S-EF) :great: THanks!!! |
timing belt eh?
timing belt eh?
| All times are GMT -8. The time now is 10:41 PM. |
