YotaTech Forums
-   General Vehicle Related Topics (Non Year Related) (https://www.yotatech.com/forums/f123/)
-   -   Lighting Setups (https://www.yotatech.com/forums/f123/lighting-setups-130650/)
toylocost Nov 24, 2007 08:26 PM
Lighting Setups
Lets see pics of everyone's lighting setups. Anything goes, if you want to comment on quality of or experiences with your setup then do so.
(sorry if this has already been done)
4Crawler Nov 24, 2007 08:38 PM
I just run the regular headlights (w/ 55/100W H4 halogen bulbs):
- http://www.4crawler.com/4x4/CheapTri...l#H4Conversion
and a pair of Hella 550 fogs under the front bumper (with some all-weather 100W H3 bulbs):
http://www.4crawler.com/Photos/103_pana/p1030475.jpg
I wired the fogs to be independent of the headlights and often use the fogs and high beams in the back country. High beams throw a lot of light down the road and the fogs fill in to the sides. Combination works well, and can also run the fogs only off-road with no headlights. Works better in the rocks, the headlights shoot too high to light up in front and to the sides of the truck like the fogs do. I can also fold the fogs back up behind the spring hangers when in big rocks to keep from damaging them. I like to keep the fogs down low since they work better and it keeps the truck street legal. I used to run the fogs above the bumper and I found out they were a few inches too high to meet the CA vehicle code.
I like to keep the lights to a bare minimum and get multiple uses out of the ones I have.
olharleyman Nov 24, 2007 08:48 PM
http://i184.photobucket.com/albums/x...d/PICT0009.jpg
Here's a shot of my 8 light set up
The roof lights are on a KCHIGHLIGHTER bar and are run in series they are 130 watts each
The lower 4 are on a Pro Comp Pre Runner Bar it was built to hold two but I did a little custom set up to fit the 4 lights they too are 130 watts each and run in series.
They are set up on two different switch's one for each set of light's I ran the wiring thru a relay to the battery back to the lighted switch's.
I also have 4 of the 55 watt HELLA light's from Cabala's mounted to the rear bumper for back up light's also set up on a relay back to the battery and returning to a lighted switch on the center console where the change thing used to be.
refried Nov 25, 2007 09:00 AM
http://i236.photobucket.com/albums/f...g?t=1196013401
Here's mine, I use Hella 90/110w headlights, and two 150w spots,(everything on relays) real simple works real well.
87AzRunner Nov 25, 2007 09:32 AM
i run two hella 500's with 100watt bulbs i swapped in,
4 underbody lights(3 are 35 w one is a 100w i want to make them all 100)
AND i use my work light, my Pizza Hut Roof sign. prolly the best light i have :)
http://i209.photobucket.com/albums/b...r/IMG_0917.jpg
tc Nov 25, 2007 09:52 AM
The headlights with PIAA bulbs and two Lightforce 240 Blitz's adjusted to wide beam. Would like to get some combo filters for them. I will never EVER have lights with glass lenses again. The abuse these have taken, plus the light output is AMAZING.
http://shim1.shutterfly.com/procgser...100CaMmTdoxYsZ
idayota Nov 25, 2007 10:32 AM
Originally Posted by olharleyman (Post 50677566)
thats a lot of light! do you find your electrical system is able to keep up? how does the alternator do? any idea how many amps each set of four 130 watt lights is pulling (i.e. what size fuse are you running)? looks good...oh yeah, what kind of lights are they? thanks!
tc Nov 25, 2007 04:04 PM
I've never been a fan of KC ... I would think if you paid for a higher quality light, you could use a lot less of them...
As for power if you're gonna run a lot of lights (IMHO rocklights are the worst offender), check out Boyle Future Tech to upgrade your alternator:
http://www.ttora.com/forum/showthread.php?t=28443
I had them redo mine after Molly had hers done, and it is AWESOME.
Chrisnxl185 Nov 25, 2007 06:13 PM
Heres my set up, i hope the picture works
Its a set of 150watt KC daylighters on a procomp light bar. They draw quite a bit, but are soo bright. And replacement bulbs are like 13$.
http://photos-056.ll.facebook.com/ph...13289_5715.jpg
http://i231.photobucket.com/albums/e...5/DSCN3179.jpg
crolison Nov 25, 2007 06:32 PM
Here is my set up, 4 hella 500's
-going to be adding a set of fogs under the front bumper
http://i150.photobucket.com/albums/s...r/IMG_2671.jpg
Elton Nov 25, 2007 06:46 PM
i got sliverstars for the headlights and 100watt streetglow slight blue tint bulbs in the hella 500s and a cheap set of fog lights the the 500s are great for being cheap
http://i63.photobucket.com/albums/h1...0Roading/3.jpg
notanymore Nov 25, 2007 08:11 PM
http://img519.imageshack.us/img519/9...42edit2tw7.jpg
http://img151.imageshack.us/img151/4...43edit2ma9.jpg
http://img151.imageshack.us/img151/7370/hpim1144se5.jpg
http://img171.imageshack.us/img171/6940/hpim1145es0.jpg
this is the 1900s compared to the 500s
http://img248.imageshack.us/img248/2956/hpim1146rf8.jpg
http://img266.imageshack.us/img266/8468/hpim1147ui5.jpg
http://img410.imageshack.us/img410/9676/hpim1148pl6.jpg
this has been finished since the picture, it is less brown looking than it does in the picture. its a scrap of smoked grey plexiglass with the paper cover left on the back of it. the green is for the bumper and red for the top lights.
http://img513.imageshack.us/img513/4...50edit2kx1.jpg
the 2 hella 500s on my bumper are 55w and the ones on the top are 100w. the hella/optilux 1900s are also 100w.
i really like the 500s and for the price they do pretty good. i wish i had left one on top with a 55w bulb in it so i could compare the brightness of the 55w to the 100 in the hella but either way they are bright as hell. the 1900s arnt quite as nice but much cheaper. like $22 each off porc and they come with 100w bulbs in them- great if you are on a tight budget and need lights, but if you can i would go for at least the 500s with 100w bulbs
wormhole Nov 25, 2007 08:22 PM
I still need to get aimed but they have done good so far.
http://i162.photobucket.com/albums/t...a/IMG_1014.jpg
olharleyman Nov 25, 2007 08:37 PM
Well I run them off a separate battery now (dual battery set up) and a stock alternator so yea electrical system has no problems keeping up with there draw. I have never really done a test to see what the draw on them is so no idea sorry but run a 30 amp fuse and relay with both Set's. The lights are supposed to be Kc's but after talking with KC they say they don't make a 130 watt replacement bulb so I am not sure what brand they are but I did find a source for replacement h4 bulbs. Hope that helps ya if you need more info just ask.
dirtyXplorer Nov 26, 2007 05:29 AM
*Hijack* sorry... but where is everyone getting those awesome prerunner bumper light bars for their 2nd gen 4 runners? like olharleyman and chrisnxl185
CJM Nov 26, 2007 05:34 AM
olharleyman, they sure do make them b/c I found them on thier site..h3 bulbs though.. http://www.kchilites.com/store/Bulbs-C98.aspx
Chrisnxl185 Nov 26, 2007 07:15 AM
I ordered mine from summit racing. i think it was around $130. I like it, its actually pretty beefy for a light bar. One word of caution, mine was not a direct fit, even though its supposed to be. If your interested in getting one i can show you what i did to mount it.
dirtyXplorer Nov 26, 2007 07:18 AM
Thanks, I will be looking into that. I like them better than just drilling holes into the bumper for lights...
Chrisnxl185 Nov 26, 2007 07:23 AM
Just because its on the KC website doesn't mean KC makes them.
I ordered a 150W Sealed beam off the website, and its not a KC bulb. Its a Wagner.
Another thing, if you can find out what the serial number of the bulb is you might be able to find it cheaper from like a light bulb warehouse (thats what i did). From KC $28 From Bulbs.com $13. Same exact Bulb!
DIHOWARD Dec 8, 2007 07:41 PM
1 Attachment(s)
headlights and fogs replaced with PIAA extreme white bulbs, BOSCH pilot driving lights, also with PIAA bulbs
