lift blocks.. this should be fun
ok so me and my co worker got in this arguement he says that lift blocks are the way to go for my 84 pickup haha i dont care if you pay me im not putting F*****G lift blocks on an 84 yota. he says all the race trucks have blocks and i said the ones you see in magazines are just show trucks "no theyre real trucks" says i tell him real trucks have springs i just cant convince him that lift blocks=crap so how bout all the yotatechers that read this tell him why you dont want lift blocks and ill show it to him on monday
One word... Leverage. Your move beatch!
Whats his reasoning that blocks are the bees knees? They offer:
No added wheel travel
No added flex
Decreased leaf spring life due to twisting
Increase axle wrap
They can break
Require long u-bolts that can snap
Will make your ride worse on a bad leaf pack, before they wreck the leaf pack itself...
No added flex
Increase axle wrap
They can break
Lift blocks?
I like to get 4 3" ones and then stack them giving me 12" of lift.
Lift blocks are worthless. I dont think I've ever seen a "true" trail truck/buggy using blocks. Ask someone who uses blocks if they have been off-road and see what they tell you.
lift blocks = poser ?
haha but i know what ya meanok thanks guys now i can prove my co worker wrong
my next task is to convince him that chad reed now rides a 450 not a 250 he doesnt believe me but its his loss we bet 20 on it
I had a set and they BOTH split down the middle. Tilted the pinion up, ripped the drive shaft out of the truck, and the axle was cocked to the side since there was now a 2" gap between the ubolts and the axle. It bent the entire drive shaft so I had to replace it. Luckily this happened while I was pulling out of the shop. Had it happened on the highway or even the street, the rear end would have been ripped off the truck and I would have crashed.
tell you friend to do the job right the first time.. if that means saving up a few more weeks then so be it.. but a stock yota locked in the rear will out wheel his "lifted" chebbie anyday!
tell him you dont need blocks cause a toyota can fit decent meats STOCK!
Yup. Many times. I checked them before every trip too.
Sad thing is, when I first installed them, one of the cracked during installation. I should have known then they were crap. But the ones I had were junk, they were from autozone, and were made of crappy pot metal. If you get steel ones they should hold up a lot better. But still doesnt make them good, there are a bunch of other problems with them like axle wrap.
back in '89 I jumped my 80 wagoneer that had 3" blocks in the rear, 4 people in the truck. Hit a big jump, landed and ripped the drive shaft off, and cracked the output shaft. Limped home in FWD. Parked the truck in my drive way and gave it to buddy two years later. Never again will I own a blocked truck.
