Hub choice
rebuilding my front axle on my 85....going with Marfields while it's apart...my question is should i go with the bullet proof hub gears for the factory yota hubs, or use the Warn hubs that i have as spares ??.....running 4:88 gears, 4.7 in the t-case, and 35's....not sure which hubs have stronger internals..... thanks for the help.
Just what are Marfields??:think:
I like my Warn Hubs I run them on every vehicle I have . Some claim they come loose due to not having cone washers when your doing hardcore off roading . I use Never Seize on my studs with no problem. Some also don`t like that they are a whole 1/4" wider then the Aisin Hubs. Thing is all the Aisin Hubs I had just never worked when they came into my possession. It is a personal Choice things mechanical will break after all some people drive those J word vehicles. |
| All times are GMT -8. The time now is 06:16 AM. |
