Help! FZJ80 Power Steering Cooler Assemnly repair
I have a leak in the cooler assembly, pictured here as number 63 http://www.sor.com/sor/cat099c.tam?xax=31212. I bought the $400 assembly but tech said 5 hours of labor, it is in a tight spot which requires moving the subframe? or radiator mount? to get the piece through as it looks. Anyone have experience doing this?
You paid 400 dollars for that ?, you could have bought a transmission cooler that would do the same thing as the part you bought, and do it alot better with the hose and clamps needed for less than a 100 dollars and put it in your self in about two hours, and save alot of money.
I used a transmission cooler and have had no problem what so ever
