Help decoding a VIN plate
I'm trying to figure out what gears this '81 longbed 4wd came with. I got the VIN jt4rn48d1b0003001, but can't seem to find a VIN decoder that tells me the factory equipment. Below the VIN is a string of numbers - 74514-35151-a, but they look nothing like the axle codes I've seen references for. Any ideas?
It's probably moot since I want 3.07's and I'm quite certain the truck has the usual 3.9/4.1. How hard are those R&P's to find for the front and rear diffs? |
Why do you wants 3.07s? Going really small tires?
My 81 came with 3.90s |
been covered many times on how to tell which gears your truck has and it has nothing to do with the vin number.
I'll be nice and post it for you so you don't have to search for it. http://www.brian894x4.com/sitebuilde...te-447x271.jpg |
Originally Posted by SCToy
(Post 51763754)
Originally Posted by xxxtreme22r
(Post 51763766)
I'll be nice and post it for you so you don't have to search for it. http://www.brian894x4.com/sitebuilde...te-447x271.jpg Oh, derp derp... I went back to Brian's site and read more carefully, that the right plate to look at is on the firewall, not the driver's door. Seller's hard to get a hold of so I'm still hoping someone can make sense of those numbers while I try to call back and have him read the correct plate. |
| All times are GMT -8. The time now is 02:12 AM. |
