Differential and accessorie question
5 Attachment(s)
Update: I've been helped and the parts will be here this week. Thanks to Millball and yotatech forums. Glad to join an active Toyota thread-
:great: 92.4runner.5speed.broken! So, as seen in the pictures, I broke my differential, bent the cross member mount for it, also the spacer for the front differential rear mount, that was a part of my pro comp lift kit. I cannot find a new front diff cover, and was going to see if a local welder could fix my cross member, but also have no clue where to get that spacer!!! first post here, excited to be here. Sure I am missing some questions but will edit soon! Thanks guys! |
I've got a spare aluminum front diff cover, and a crossmember too Where are you located??
Maybe a welder could replicate thespacer?? |
I live in Tucson but am broken down in Flagstaff
Willing to pay for the parts and possibly have them shipped here if you were willing! Let me know, going to go to the U Pull It up here today, will update later! |
I live near Tucson. PM me. I'll try to see if these parts will fit in a Flat rate priority mail shipping box.
3 Attachment(s)
IFS pics:
Those will be just right! Also, off of my differentials right side, where the cv attaches to the flange, it is tweaked a bit, I was told that it should be safe with how the axle/bearings move, but feel skeptical about it. Thoughts? Just don't want to replace that part if the differential is no good.
Originally Posted by Bubbazeus
(Post 52370810)
Would insert video if I knew how. You can see that in different positions of that rotation, the slight, somewhat drastic wobble.
If it does not run true, it is unuseable. I send PM
https://cimg8.ibsrv.net/gimg/www.yot...b02611a55b.jpgRight beneath the drain bolt, to the right, there is spacing for the flange on the ADD actuators electrical connection point. Minor difference, but with the new plate, the actuator cannot be mounted.
*Front differential vacuum actuator
my first truck, and 4wd. Apologies for the lack of proper terms. |
