Add Wheel Speed Sensors to Toyota Ten Bolt
As part of a tech school student project I need to detect the rotating speed of the rear wheels on a Legends race car. These cars use shortened Toyota "ten bolt" rear axles. Is it possible/practical to install ABS sensors, or similar rotation sensors, on these axles?
There are differentials (for ABS equipped vehicles) with a single speed sensor mounted over the ring gear. You could put one of those in and use the existing sensor (reads speed off the teeth of the ring gear).
Originally Posted by 4Crawler
(Post 50910896)
So it sounds I need an ABS rear end because it's not practical to install ABS sensors on a non-ABS rear end. Is that right?
What does an ABS setup look like anyway? I seem to recall that ABS has a wheel with teeth, kind of like a gear, mounted on the axles. Sensors aimed at the teeth generate electrical pulses as the teeth on the "gear" pass by. The pulses are read by a computer. Is that right? I just don't recall where the gear wheel is located. Is it made onto the axles? Or can it be installed on the axles? |
90-95 4Runners have a single ABS sensor mounted right square on top of the differential.
96-current 4Runners have left and right ABS sensors mounted at the axle flanges near the brakes. |
The legends cars need 6 5/8 rears (IIRC, i may be slightly off) you cannot drop a Toyota 8" diff into them. I think the legends cars are only allowed to run certain gears and housings too, so dropping in a truck housing isn't an option either.
