87 vs 83 22r Igniter compatibility question
Hey fellas, anyone know if the igniter assembly off a 83 22r part number 89620-35H93 will work on my 87 22r pickup with currently broken igniter assembly part number 89620-35140? They look the same and I found a new replacement for an 83 but the differing part numbers are concerning. Any help is greatly appreciated.
If you have Both EWD`s sit down and compare the pin outs .
It might just be a case of moving a wire or two On the 87 you will have the 2 green plugs with 2 wires 1 green plug one wire the one wire plug green wire goes to the check connector The one green 2 wire plug has a Black /Red wire coming from the Ignition Switch black wire going to the tach on the ECU The other two wire Green Plug goes to the Distributor either a Red or Pink wire and a White one Hope that helps |
