12.5" wide tires on a 13" wide rim
Is it safe? What's a good rule of thumb in relation to tire and rim width?
I read somewhere that you generally can do about 1.5" wider and 1.5" slimmer than the rim, regarding tire width. |
go with a 10'' wide rim
Are you from Hawaii?
Well, the tire width is measured at the widest point in the sidewall. So the actually bead width is probably about 2" narrower... I wouldn't recommend it. To be safe, most people have a rim that is at least 2" narrower than the said tire width.
Originally Posted by Swissdrums
(Post 991634)
Well, the rims are 15 x 13, all 4 for $40 only!!! I don't want to pass it up!!
you can do it but dont expect to air down while offroading or else tire is destroyed
https://i2.tinypic.com/t65uzt.jpg thats an example i do not suggest this method at all!!! |
Just because is a monetary deal does not mean it is intelligent to buy it. You want a rim at least 2" narrower than your tire IMO as the general ROT.
And it will look STUPID! :hillbill: :guitar: |
Wow. That truck does look dumb...
But, if I bought them, I would probably end up putting 14 to 15" wide tires on. But those are costly and require massive clearance, so I guess I'll let this deal slide. But, If anyone wants them, they are posted on ebay. I'm not sure the item #, but if you type in "MUST SEE RIMS", letter for letter, they will pop up. To shift gears slightly, a good ROT is 2" slimmer than your tires? I would guess for deflation purposes? |
Originally Posted by waskillywabbit
(Post 991940)
And it will look STUPID! :hillbill: :guitar: I suggest 3 or 4 inches. The truck above is so stupid. |
13 inch rims are for like 17 or 18 inch drag tires....not for our trucks!
But it's a good deal... :cry:
Oh well. Thanks all. |
A good deal is a good deal... but is a broken bead and all the hassle of fixing a good deal? MEH..!
