1/8" BSPT conversion fitting
Trying to find this:
1/8" BSPT male to 1/8 or 1/4" NPT fitting. NPT can be male or female. Trying to do some plumbing with my ARB lines and compressor. They come with 5mm lines and all sorts of metric, BSPT fittings that I am trying to Americanise. If any one has a link to a supplier or other options that would be great. I have had zero luck at the local level. |
Go to http://www.mcmaster.com/ then page 28 and see if that has what your looking for at the bottom.
Erich |
Or just get a tap, the threads are REALLY close - just need to chase them with the right tap/die.
McMaster.... I knew there was a place for all that but hadn't bookmarked it. They have whay I need. :great:
I'll keep the tap idea in mind, but I will go with the fittings for now. |
| All times are GMT -8. The time now is 02:06 AM. |
