Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
94 toyota pickup transmission swap
Old 02-10-2018, 04:28 PM
Kadi96915's Avatar
Ok so im done with the swap of auto to standard on my 94 toy 4x4, got reverse lights working original and i bypassed the vaccum for the front diff. My question is how many qts of gear oil for just the trans itself not the tcase just the trans? I drained the tranny and over 4qts of gear oil came out and ive been hearing and read up on it that only 2. Some qts for drain and refill. Well i did the drain and refilled it to too of fill plug and it wont go i to any gear. Im thinking of adding a couple more qts just to see if it will shift but before i do that im hoping someone here can give me some ideas before i do this. Keep in mind that it was shifting good before i did the drain n refill. Pls any info would be great. Thanks
Kadi96915 is offline
Old 02-10-2018, 04:41 PM
millball's Avatar
Changing the gear oil probably has nothing to do with your issue.
If the gear oil is up to the where it comes out the side level plug the tranny is full.
Look to the clutch hydraulics.
millball is offline
Old 02-10-2018, 05:37 PM
Kadi96915's Avatar
Clutch slave and master are brandnew, i have a centerforce 1 clutch with stock clutch plate. I flushed and blew the lines and its free n clear. Forgot to mention this trans i installed sat for alittke over 2 years.
Old 02-10-2018, 06:01 PM
millball's Avatar
In your first post you stated that it shifted just fine until you changed the oil.??????
Has it ever run and shifted since you assembled it??
millball is offline
Old 02-10-2018, 08:54 PM
Kadi96915's Avatar
Not shifting
After i installed the trans and everything else it was shifting good and all. What im saying is that after i drained the gear oil alittle over 4 qts came out of trans. So when filling it on the fill side of trans it said 2. Some qts which is weird when alittle over 4qts came out. I did fill it til it started coming out of fill plug, alittle over 2 qts and then it started spilling out. That is why im asking what is the total qts that the Trans take not the tcase just the trans.
Kadi96915
02-06-2018 05:47 AM
jacobtodd123
02-25-2015 07:53 PM
despaj0
11-07-2012 10:03 AM
4X4Yota4X4
All Other Toyota Swaps
01-23-2010 08:16 PM
dixiemuddtoy
09-22-2009 01:04 PM
Quick Reply: 94 toyota pickup transmission swap
