***NEW SECTION*** YotaTech's Glossary - submissions needed
YotaTech is finally going to be getting a dedicated Glossary!
This section/thread will contain everything from "SAS" to "IFS" to the various Toyota engines. In order for this to work we need your help. I am going to leave this Sticky open for you all to post in. Only rule for this thread, no BS. Post up a glossary term, the definition and that is it - no smilies, no banter back and forth, etc... I will go through and edit it grammatically and for formatting. If you have an image that is associated with your definition feel free to post it - if you do this, please make the image small, I would say 640x480 at most. Keep in mind when posting that it is your responsibility to ensure the definition/image you are posting is not Copyright'd or Trademark'd. Please look and make sure somebody hasn't already posted it. If you have any questions or you believe that a definition that has already been posted is incorrect, please PM me or another Mod and we will see that it gets corrected. Remember, this is a glossary not a dictionary. Thanks for your help, YotaTech Staff |
TECH TERMS
2H - 2-wheel drive / high range 4H - 4-wheel drive / high range 4L - 4-wheel drive / low range A/T - All-Terrain; often used when referring to tires, a tire that is more apt to off-road conditions however less aggressive than a mud-terrain tire AAL - Add-a-Leaf ABS - Anti-lock brake system ADD - Automatic Disconnecting Differential System; disconnects the front axles and hub assemblies from the drive shaft at the differential when the vehicle is in 2-wheel drive mode, eliminating the need to disconnect them manually. It also engages the front axles to the differential when 4-wheel drive is selected Air Down - Partially deflating tires to improve traction Air Locker - Pneumatically-activated differential locker ARB - Manufacturer of high-quality aftermarket 4x4 accessories, including their patented air locking differential as well as armor for all areas of your 4x4 AT-PZEV - Advanced Technology Partial Zero Emission Vehicle; vehicles that produce extremely low levels of hydrocarbons and oxides of nitrogen A-TRAC - Active Traction Control; incorporates sensors at all four wheels to monitor a loss of traction, Active TRAC employs brake and throttle control to reduce wheel spin and transfer torque to the wheel with the most traction. Auto LSD - Automatic Limited-Slip Differential; differential that automatically distributes power to the wheel that has traction, this type of differential is preferred in slippery conditions (snow, ice, gravel, etc...) BFG - B.F. Goodrich Tires CAI - Cold Air Intake CARB - California Air Resources Board Cat - Catalytic converter; exhaust device installed before the muffler to reduce emissions (Cali-spec models have dual cat's) Cat-Back - Exhaust system after the catalytic converter CEL - Check Engine Light CHMSL - Center High-Mount Stop Lamp COG - Center of Gravity CRS - Child Restraint System CV - Constant Velocity DAC - Downhill Assist Control; system that automatically applies the brakes during a downhill descent without locking the wheels DOHC - Double Overhead Cam DOT - Department of Transportation DRL - Daytime Running Lights ECM - Electronic Control Module ECT - Electronically Controlled Transmission; automatic transmissions only ECT-i - Electronically Controlled Transmission with Intelligence; automatic transmissions only ECU - Electronic Control Unit EFI - Electronic Fuel Injection EGR - Exhaust Gas Recirculation E-Locker - Electronic Locking Differential FJC - FJ Cruiser (2006+) Fob - Key ring remove device; door locks, remote start, etc… FSM - Factory Service Manual; repair manuals written by Toyota and used by all Certified Toyota Technicians GAWRF - Gross axle weight rating front axle; the max weight the front axle is designed to carry GAWRR - Gross axle weight rating rear axle; the max weight the rear axle is designed to carry GPS - Global Positioning Satellite GVWR - Gross Vehicle Weight Rating; maximum combined weight rating including the vehicle and its equipment, fluids, occupants and cargo. HAC - Hill-Start Assist Control; automatically increases brake pressure to all four wheels to reduce rolling backwards while accelerating uphill. HID - High Intensity Discharge; extremely bright, often blue in color, low-wattage lights IFS - Independent Front Suspension LCA - Lower Control Arm LCD - Liquid Crystal Display LED - Light-Emitting Diode LEV - Low Emission Vehicle Live axle - Straight axle (non-IFS) Locker - Device put in differentials to lock gears together providing exceptional off-road traction. Locking Hubs - Engage-able free-spinning front hubs (i.e. Aisin manual hubs); preferred due to the ability to reduce wear on components when 4-wheel drive is not engaged. LSD - Limited Slip Differential; type of differential that improves traction by splitting torque evenly and preventing one wheel from slipping or spinning, this type of differential is preferred in slippery conditions (snow, ice, gravel, etc...) LSPBV - Load-Sensing Proportioning and Bypass Valve; mounted to the frame and the rear axle, the LSP & BV senses the weight distribution of the vehicle and automatically varies the amount of hydraulic pressure to the rear brakes based on the load in the vehicle, this helps to reduce rear-wheel lock-up with either light or heavy loads to maintain stopping control. M/T - Mud-Terrain; often used when referring to tires, a tire that is made specifically for off-road conditions MAF - Mass Air-Flow Sensor OBA - On-Board Air OBD/OBD II - On-Board Diagnostics OEM - Original Equipment Manufacturer OHV - Off-Highway Vehicle OME - Old Man Emu PCM - Powertrain Control Module PCV - Positive Crankcase Ventilation R&P - Ring and Pinion; differential gears RR Diff Lock - Rear Differential Lock RSCA - Roll-sensing Side Curtain Airbag SAC - Solid Axle Conversion SAS - Solid Axle Swap SAW - Sway A Way SFA - Solid Front Axle SOA - Spring Over Axle SOHC - Single Overhead Cam SRS - Supplemental Restraint System; airbags inflated with nitrogen gas that deploy within a fraction of a second SULEV - Super Ultra Low Emission Vehicle TPMS - Tire Pressure Monitoring System; alerts the driver by illuminating an indicator on the dash when tire pressure reaches a critically low level TRAC - Traction control; helps to avoid slippage of the driving wheels by slightly applying the brake on a slipping drive wheel and reducing the throttle to maintain traction according to the road surface conditions. TRD - Toyota Racing Development TSB - Toyota Service Bulletin UCA - Upper Control Arm ULEV II - Ultra Low Emission Vehicle II Unibody - The floor pan of a vehicle and chassis are connected to form a single structure; there is no separate frame. By welding all body panels together to form the vehicle's frame, it is possible to build in strength and rigidity with less weight. URD - Underdog Racing Development; manufacturer/distributor for various aftermarket performance parts including the TRD Superchargers VSC - Vehicle Stability Control VVT-i – Variable Valve Timing with Intelligence; varies the timing of the intake valves by adjusting the relationship between the camshaft drive (belt, scissor-gear or chain) and intake camshaft. Engine oil pressure is applied to an actuator to adjust the camshaft position. WOT - Wide-Open Throttle Y-pipe - Pipe used to split/bypass the exhaust FORUM LINGO AFAIK - As far as I know BFH - Big f'ing hammer BTT - Bring to top BTW - By the way BUMP - Posting to bring an old thread back to the top DD - Daily driver DIY - Do-it-yourself FORD - Fix or repair daily / Failure of research & development / Found on roadside dead FS - For sale FTW - For the win FUBAR - F'd up beyond all recognition FWIW - For what it's worth FYI - For your information HTH - Hope this helps/helped IIRC - If I remember correctly IMHO - In my humble/honest opinion IMO - In my opinion LMAO - Laughing my ass off LOL - Laugh out loud NIB - New in box PITA - Pain in the ass POS - Piece of s*** ROFL - Rolling on the floor laughing RTFM - Read the f'ing manual TIA - Thanks in advance TTT - To the top WTB - Want to buy... WTF - What the F? WTH - What the hell? WTS - Want to sell... WTT - Want to trade... TOYOTA ENGINES 20R 2-valve SOHC 2.2L (2189cc) produced from 1975 to 1980 Output was 96hp at 4800rpm and 120ft•lbf at 2800rpm. Applications: 1975-1980 Toyota Hilux 1975-1980 Toyota Celica U.S. Version 1975-1980 Toyota Corona U.S. Version 21R 2-valve SOHC 2.0L (1972cc) produced from 1978 to 1987. Cylinder bore was 84mm (3.31 in) and stroke was 89mm (3.5 in). Output was 105hp at 5200rpm and 116ft•lbf at 3600rpm. 21R-C (California) 2-valve SOHC 2.0L (1972cc) produced from 1982 to 1985. Cylinder bore was 84mm (3.31 in) and stroke was 89mm (3.5 in). Output was 90hp at 5000rpm and 116ft-lbf at 3600rpm. 21R-U (Japanese) 2-valve SOHC 2.0L (1972cc) produced from 1982 to 1985. Cylinder bore was 84mm (3.31 in) and stroke was 89mm (3.5 in). Output was 105hp at 5200rpm and 120ft•lbf at 3600rpm. 22R The 2-valve SOHC 2.4L (2366cc) produced from 1981 to 1995. Cylinder bore was 91.9mm (3.62 in) and stroke was 88.9mm (3.5 in). Initial output was 97hp at 4800rpm and 129ft•lbf at 2800rpm. By 1990 the 22R was producing 108hp at 5000rpm and 138ft•lbf at 3400rpm. Applications: 1981 Toyota Corona 1981-1988 Toyota Hilux 1981-1984 Toyota Celica 1981-1995 Toyota Pickup 1984 Toyota 4Runner 22R-E The 2-valve SOHC 2.4L (2366cc) produced from 1983 to 1995. Cylinder bore was 91.9mm (3.62 in) and stroke was 88.9mm (3.5 in). Output of these engines is commonly rated at 105hp at 4800rpm and 137ft•lbf at 2800rpm. In 1985, the engine was significantly reworked, output was up to 112hp at 4600rpm and 142ft•lbf at 3400rpm. Many parts from the newer 22R-E are not compatible with those from the older pre-1985 engine. Non-compatible parts include the cylinder head, block, pistons and many of the associated parts such as the timing chain and cover, and water and oil pumps (although the oil pump internals are the same). Applications: 1985-1995 Toyota Hilux 1983-1985 Toyota Celica 1985-1995 Toyota Pickup 1985-1995 Toyota 4Runner 22R-TE 2-valve SOHC 2.4L (2366cc) produced from late-1985 to 1988. Cylinder bore was 91.9mm (3.62 in) and stroke was 88.9mm (3.5 in). Output was 135hp at 4800 rpm and 173ft•lbf at 2800rpm. Applications: 1985-1988 Toyota Hilux 1987 Toyota 4Runner 3VZ-E 3.0L (2958cc) produced from 1988 to 1995. Cylinder bore was 87.5mm (3.4in) and stroke was 82.0mm (3.2in). At introduction output was specified as 145hp then later bumped to 150hp at 4800rpm with 180ft•lbf of torque at 3400rpm. Despite sharing an engine family designation the 3VZ-E and 3VZ-FE have few parts in common. Applications: 1988-1995 Toyota 4Runner 1988-1995 Toyota Pickup 1993-1995 Toyota T100 3VZ-FE 3.0L (2958cc) produced from 1992 to 1997.5. Applications: 1992-1997 Toyota Camry 5VZ-FE 3.4L (3378cc) produced from 1995.5 to 2004. Cylinder bore was up to 93.5mm (3.7in) and stroke was 82.0mm (3.2in). Output is 201hp at 4800rpm with 220ft•lbf of torque at 3600rpm. Cast iron engine block, aluminum DOHC cylinder heads, uses MFI fuel injection, has 4 valves per cylinder with bucket tappets and features large cast connecting rods, a one-piece cast camshaft, and a cast aluminum intake manifold. Applications: Toyota Tacoma Toyota Tundra Toyota T-100 Toyota 4Runner Toyota Land Cruiser Prado Toyota Granvia 1GR-FE 4.0L (3955cc) produced from 2003 to present. Bore is 94mm and stroke is 95mm. Output is 236hp at 5200rpm with 266lb•ft of torque at 4000rpm on 87 octane, and 239hp at 5200rpm with 278lb•ft at 3700rpm on 91 octane. Features Toyota's VVT-i technology. Applications: 2006 - present Toyota FJ Cruiser 2005 - present Toyota Tacoma 2003 Toyota 4Runner/Hilux Surf 2007 Toyota Land Cruiser 200 2003 Toyota Land Cruiser Prado 2005 Toyota Hilux 2005 Toyota Tundra 2007 Toyota Tundra 2005 Toyota Fortuner Fink:devil: |
Bump.
Thread open. Fink:devil: |
Bump.
Come on guys, I know you've got ideas. Fink:devil: |
CV - constant velocity
EFI - electronic fuel injection LSBPV - load sensing brake proportioning valve DOT - Department of Transportation CARB - California Air Resources Board ADD - Automatic Disconnecting Differential ECU - electronic control unit PCM - powertrain control module EGR - exhaust gas recirculation PCV - positive crankcase ventilation AFAIK - as far as I know IMHO - in my humble opinion |
Originally Posted by RobD
(Post 51200758)
EFI - electronic fuel injection LSBPV - load sensing brake proportioning valve DOT - Department of Transportation CARB - California Air Resources Board ADD - Automatic Disconnecting Differential ECU - electronic control unit PCM - powertrain control module EGR - exhaust gas recirculation PCV - positive crankcase ventilation AFAIK - as far as I know IMHO - in my humble opinion Fink:devil: |
Bump.
Fink:devil: |
fwiw- for what its worth
btw- by the way btw...the 5vzfe motor was up until 2004...not 2002 as stated above. |
SAC-solid axel conversion
OBA- On Board Air TRD-Toyota Racing Development (an option on toyota tacomas and newer models that generally means the vehicle is equiped with bilstein shocks all around and a factory rear locking differential.) |
ABS = Anti-Lock Brake System
CEL = Check Engine Light CRS = Child Restraint System A-TRAC = Active Traction Control A.D.D = Automatic Disconnecting Differential ECT = Electronic Controlled Transmisson SAW Coilover = Sway A Way Coilover VSC = Vehicle Skid Control RR Diff Lock = ReaR Diff Lock FTW = For The Win |
Originally Posted by HazMat
(Post 51204686)
(Post 51204687)
Originally Posted by Rock Slide
(Post 51205639)
CEL = Check Engine Light CRS = Child Restraint System A-TRAC = Active Traction Control A.D.D = Automatic Disconnecting Differential ECT = Electronic Controlled Transmisson SAW Coilover = Sway A Way Coilover VSC = Vehicle Skid Control RR Diff Lock = ReaR Diff Lock FTW = For The Win Keep 'em coming guys, I'll start to alphabetize them when we get enough on here. Fink:devil: |
Got bored last night, did a little Google'ing and research on Wikipedia.
I added a crap ton of terms and lingo. Check it out and see if I forgot anything. I compared a lot of it to the Toyota Corporate Glossary on their website and I think we're good. Fink:devil: |
POS: Piece of sh**.
I'm sure I'll think of more later on. |
:lol:
Added that one and I thought of my own...look under Forum Lingo in the F section. Fink:devil: |
DD "Daily Driver"
Originally Posted by mbuhr66
(Post 51349440)
DD "Daily Driver"
:bump: Fink:devil: |
GAWRF gross axle weight rating front axle; the max weight the front axle is designed to carry
GAWRR gross axle weight rating rear axle; the max weight the rear axle is designed to carry GVW Gross vehicle weight; the maximum combined weight rating of the vehicle is designed for, including the weight of the vehicle, installed parts and components, and all persons inside |
how about...
3.slo
Refers to the lethargic 3.0L V6 in 88 to 95 Toyotas
:guitar: |
lmao i know, i just wanted to see if that'd be an acceptable addition :)
| All times are GMT -8. The time now is 12:26 PM. |
