will 31's or 32's fit on a lifted '99?
I have a 99runner and was going to go with a a 2.5 cornfed lift with 1 inch diff drop. I have the stock 16's on there right now. I was thinking about some new 16inch wheels but before I do that I want to know if I could put 32's on without rubbing.
yes... you only really need a 1 inch body lift to fit 32s w/o rubbing... check out the Toyota FAQ thread in the noobie section.
You dont really need any actually...its sort of a debat-ish type of thing.
I have a 97 that I was able to git 32's on easily; only thing needed was I took snips and cut off about 1/2" of the inner mudflap area. You have a 99' which is taller than all other years. You should be fine. BTW I am defining 32's as 265/75/16 |
Hey E-money;
Im Running 32" MTR's on my 97 4Runner, With 16" wheels!! And I have no Lift on my rig and theres's no rubbing, after i Trimed the bottom of the bumper Flares!! Good Luck |
if it is strictly a street queen and you dont mind a bit of rubbing during turns, than yes you can run them as the 99 coils are a bit taller than other years...
but if you are going to wheel it, you will need a lift. In that case please consult the 1 million plus posts on this topic thank you. :yotarock: holy crap, please search nexttime. :barf: |
Originally Posted by ricky
Isn't that more like 30.8"?
265/75/R16 is 31.8x10.4 |
| All times are GMT -8. The time now is 09:47 PM. |
